Offline mb300e4m
#1 Posted : 28 December 2025 19:18:58(UTC)
mb300e4m
I recently acquired a 49981 Schimmel Exhibition Car w/ Sound. It only plays one piano piece so it gets abit boring after a while.
Can someone point me in the right direction for some music downloads?
Plus, assuming I can find some, how do I upload them?
Thanks in advance.
Peter B.
Peter B.
In Sunny Florida most of the time.
Marklin, Trix Express, Trix Twin, Fleischmann, Liliput, Hornby Dublo, and Others, 2 & 3 Rail, AC, DC and Digital, Course Scale Wheels & Fine, 1935 to 1960s usually.
thanks 2 users liked this useful post by mb300e4m
#2 Posted : 29 December 2025 01:31:18(UTC)
Unfortunately the manual for the 49981 is not available online, but the product description says " Different classical piano pieces can be played with the 6021 Control Unit. Volume can be adjusted." so I suspect that by selecting combinations of some functions allows selection of different pieces.
This item is too old for being able to replace the sounds, having been produced in 2003.
#3 Posted : 29 December 2025 03:03:04(UTC)
Hello Peter,
You may find within the content of post #24 here of use.
Might what is usually the loco speed throttle then control the music volume in this scenario?
Have fun,
PJBigGrin
Offline bph
#4 Posted : 29 December 2025 12:46:39(UTC)
more info in it here:
https://www.web-hgh.de/index_jsm_moba.htm?https://www.web-hgh.de/p03_maedig_fkt_so-49981.htm
It's basically a custom sound chip, controlled by an old 60902x locomotive decoder.
does not seem like there is much you can do unless you upgrade/rebuild it with a new sound decoder etc.
Offline Jimmy Thompson
#5 Posted : 29 December 2025 16:35:52(UTC)
Jimmy Thompson
A Jimmy-style side bar...here is a video that would indicate more than one sound bite available...however, as noted above, it is unlikely that one can download other options...Crying
https://www.youtube.com/watch?v=o_EPrDo_Dp4
And here is one that narrates the instructions (without showing them per se) - might be of help...Cool
https://www.youtube.com/watch?v=hxXuhXLNPCk
Whisper Mode On And 22/23 years is a (very) long time in re applications of techno...Whisper Mode Off
I also have wished for miracles of downloads on this car (I do not have it as yet, but, one lives in hope LOL ), and have thought about posting it at the Vollmer Piano Fabrik model and running sound through a speaker under the factory Sneaky , but that does somewhat limit its use...RollEyes (and I suspect that as I run analogue on M-track, I should isolate the siding to the factory so that I do not fry the wee circuits of the car Crying - I just like the car Cool )
Edited by user 31 December 2025 18:07:07(UTC)  | Reason: add 2nd link
Jimmy T
Dr Dirt's Rule #1 and
Offline Dave Banks
#6 Posted : 29 December 2025 21:18:51(UTC)
Dave Banks
D.A.Banks
thanks 3 users liked this useful post by Dave Banks
Offline bph
#7 Posted : 29 December 2025 23:45:40(UTC)
One option might also be to investigate if it's possible to upgrade it with the decoder and electronics from 43868 or 43948, if the parts can be found.
as the music is stored on a SD card in these models.
sounds etc, for those are available here: https://www.maerklin.de/de/service/downloads/produktunterstuetzung
(The Nächste Haltestelle disco song is the most unique next station announcement from märklinCool )
offcourse you could also go alternative routes with a 3rd-party mp3 SD card player etc, or just a Bluetooth device that plays whatever you send to it.
Offline mb300e4m
#8 Posted : 06 January 2026 01:11:20(UTC)
mb300e4m
Thanks everyone for the suggestions. I'll check them out.
Even if I cannot add more music, it is still a nice looking piece of rolling stock.
I'll have to take it apart and see what is inside.
Peter B in a sunny but cool Florida.
Peter B.
thanks 1 user liked this useful post by mb300e4m
Offline EB421
#9 Posted : 06 January 2026 02:23:44(UTC)
EB421
Silly question, but looking at the inside photos - if the decoder is just triggering the sound chip; in theory you could hardwire an MLD, LokPilot, or any other modern DCC/MFX decoder with four outputs to trigger the existing sound chip? Is that correct?
Would obviously mean lots of soldering with concommittent risks, but it should work, right?
thanks 1 user liked this useful post by EB421
Offline bph
#10 Posted : 11 January 2026 15:07:23(UTC)
hi,
It looks like the decoder used in the 49981, was also used in some locomotives, so you probably should be able to make the sound board work with a modern decoder. HGH also writes that on the page.
Note that there were some variations on the decoder, so it is at your own risk. Some more information here: https://moba-hgh.de/modellbahn/digital/decoder/fuer-lokomotiven/maerklin/digital/6090x-c90x?id=148#c6090x-f1-f2-f3-f4-2
This page was generated in 0.689 seconds.
