Offline dave55uk
#1 Posted : 26 December 2025 22:18:41(UTC)
dave55uk
On the MS2, when one changes the loco name, is there a backspace character at all?
Offline rhfil
#2 Posted : 27 December 2025 12:25:15(UTC)
rhfil
If I remember there is one but not easy to find. I seem to remember something about requiring two fingers.
#3 Posted : 27 December 2025 15:19:12(UTC)
Review MS2 basics. Videos on You tube as well. Go to the change Loco menu. Select name, or address using the button next to the desired function arrow. Hold the shift key and Rotate the knob counterclockwise or clockwise to the number or character to be changed till the desired number or letter shows. Then use the left or right arrow to got to the next number or character you want to edit.
Once you are finished, push the check mark to save the changes or send the new address to the Loco.
Offline dave55uk
#4 Posted : 27 December 2025 20:26:53(UTC)
dave55uk
I will investigate that, many thanks.
#5 Posted : 27 December 2025 22:01:03(UTC)
There are two ways to enter loco names.
I always use the keyboard mode and with that mode you can move the cursor left and right as needed IIRC.
Offline dave55uk
#6 Posted : 27 December 2025 23:07:25(UTC)
dave55uk
Yes, that's right.
But where it says "DCC 165-002" TRAXX [a made up example], I want to delete the "DCC " bit without
having to overwrite it with the number, which then shifts it all to the left. I was just wondering if there
was a delete button that would delete the previous character. rhfil has given me an idea.
thanks 1 user liked this useful post by dave55uk
Offline osoraku
#7 Posted : 30 December 2025 17:06:28(UTC)
osoraku
Dear Dave -
I discovered with my MS2 today that the button labeled with ⬅︎ is the delete character key (see photo). The bottom left button activates the function.
Now I need to find the insert key to get my letters in the middle back!
Osoraku
thanks 3 users liked this useful post by osoraku
Offline dave55uk
#8 Posted : 31 December 2025 17:36:59(UTC)
dave55uk
Osoraku - You are a star! Many, many thanks.
(How on earth did I not see that?).
OceanSpiders 2.0
This page was generated in 0.479 seconds.
