Offline Kiko
#1 Posted : 22 December 2025 22:33:25(UTC)
Kiko
Hello All,
My BR41 (Marklin #37923) locomotive drives very well, but the wheels on the front bogie sometimes just ride the rails and don't spin. It's an annoyance that I'd like to resolve.
I've already played with the copper "spring" that provides tension and ground contact between the loco body and the front wheel axle. This made a very insignificant difference. What else can I try?
Any suggestions would be welcome. Thanks!
Andry
Andry
Offline RudiC
#2 Posted : 22 December 2025 23:03:31(UTC)
RudiC
Views messages in topic : 194
Does the bogie move freely up and down? Do the wheels spin easily when manually driven? I'm sure you cleaned and oiled the axles.
Rüdiger (Rudi)
#3 Posted : 22 December 2025 23:52:02(UTC)
Views messages in topic : 3,667
Ouch; Be careful touching the springiness of the wheel, as any wrong setting can cause derailments over points!
Other than that, you can try to pop out the axle (wheel set), and assure that everything is clean and parallel, and that there is nothing irregular with the plastic part of the bogie. Clean out any old sticky oil, and maybe give it a tiny drop of fresh new oil.
Check the inner spacing of the wheels and that they spin freely.
Offline mvd71
#4 Posted : 23 December 2025 00:50:07(UTC)
Views messages in topic : 1,987
Sticky old oil is usually the problem. Needs to be cleaned out and re-lubed. You might be able to soak it in smoke fluid to soften it up.
Offline rhfil
#5 Posted : 23 December 2025 01:31:54(UTC)
rhfil
If the wheels don't turn there mist be something causing friction. The spring you adjusted serves two purposes - keeping the bogie on the track through switches and putting the wheels in contact with the rails. Any petroleum product will dissolve the old oil. Anything you have available - paint thinner, starter fluid, lighter fluid, gasoline. Even smoke fluid though that usually has paraffin in it. You can lubricate whatever holds the axle in place with a light oil or any friction reducer such as teflon, silicone or graphite. The wheels should turn freely with the slightest touch. I can't tell what your loco uses.
Offline Kiko
#6 Posted : 23 December 2025 16:24:01(UTC)
Kiko
Hello Rudi,
Thanks for your reply. Yes, the bogie moves freely and the wheels spin easily. I will once again remove the wheels from the bogie and clean them with lighter fluid then re-lubricate. Won't hurt to do the process once again and see if it helps.
Andry
Offline Kiko
#7 Posted : 23 December 2025 16:28:11(UTC)
Kiko
Hello Henrik,
Thank you for the warning. I've done many loco repairs and conversions and I'm aware how sensitive these things are. There's nothing irregular that I've noticed about the bogie. I will follow your advice and check the wheel spacing. However, the wheels do spin nicely, but maybe they are just set too narrow, as opposed to too wide. I'll look into this.
Andry
Offline Kiko
#8 Posted : 23 December 2025 16:30:13(UTC)
Kiko
Hello mvd71,
Yes, I'll do the cleaning once again, but I've already done that and it did not help. Won't hurt to do it again.
Andry
Offline Kiko
#9 Posted : 23 December 2025 16:37:34(UTC)
Kiko
Hello rhfil,
The wheels do spin nicely -- very little friction. However, when the loco is driving, sometimes the wheels just "float" ever so slightly above the rails. I've already bent the copper "spring" to force the wheels down, but this did not completely solve the problem. I've had this problem with another loco (S3/6) but bending that copper spring resolved the issue. In this case (BR41), the problem still persists. I'll re-clean the whole bogie and will lubricate once more (very small amount of teflon grease) and see what happens. I might even attempt to bend that copper spring a bit more.
Thanks for your input.
Andry
thanks 1 user liked this useful post by Kiko
#10 Posted : 23 December 2025 16:42:47(UTC)
If it doesn't derail, can you add a soapbox derby small square weight under the front of the frame?
Offline rhfil
#11 Posted : 23 December 2025 19:00:36(UTC)
rhfil
"The wheels do spin nicely -- very little friction. However, when the loco is driving, sometimes the wheels just "float" ever so slightly above the rails." My favorite engine - 39241 - suddenly started shorting at one switch on our club layout. I finally read that the little copper spring might be the issue so took it apart to increase the tension. But I then noticed that something wasn't quite right and discovered that I had put it back together incorrectly and the spring was pushing the wheels slightly to the side. You might want to take the bogie apart again and put it back together more carefully. It sounds like the problem is similar to what I found.
Online Copenhagen
#12 Posted : 23 December 2025 21:20:24(UTC)
Copenhagen
Yeah, there is likely not enough weight on the front wheels.
Later edit: not the problem in this case. Glad that it got resolved.
Edited by user 24 December 2025 14:11:55(UTC)  | Reason: Not specified
#13 Posted : 23 December 2025 22:46:48(UTC)
Ah, in that case it is possible that the copper spring has been installed upside-down (*). I hope you didnt bent it too much to counter any possible reverse position...
(*) PS: Speaking from experience! RollEyes
Offline applor
#14 Posted : 24 December 2025 01:00:55(UTC)
applor
I've had this problem before. My BR 75.4 from Marklin has this problem new out of the box.
I should get around to fix it. On another loco with this problem the axle slot wasn't milled enough, too tight on the axle. I slightly enlarged the hole with the correctly sized drill bit to resolve.
Offline Kiko
#15 Posted : 24 December 2025 02:07:14(UTC)
Kiko
Hello All,
In short -- I have resolved the problem. BigGrin  A big thanks to all!
I've attached a few pictures of the front bogie with wheels on and wheels off.  The wheel axle is clipped into a plastic holder, so the axle rotates inside this holder.  There are two copper "fingers" that ride on the axle and provide a ground return via the copper "spring", which in turn rubs on the loco body.  This copper "spring" also acts as a push-down lever to keep the wheels on the rails.
The design is such that there's no way to assemble the wheels and copper "spring" in a wrong way.  So that was crossed off my list.  Next was to bend the copper "spring" a little bit more, but not so much as to create too much friction.  The culprit in my case were those two little "fingers" that ride on the axle and provide an additional ground.  The wheels turned nicely but I sensed some friction.  Additional lubrication would not help.  So I gently lifted those two "fingers" and relieved some pressure on the axle.  That did the trick!
I hope that this solution helps someone else with a similar problem.
Thanks once again to all that contributed!  Cheers and Merry Christmas!
Andry
Andry
thanks 7 users liked this useful post by Kiko
#16 Posted : 24 December 2025 11:04:31(UTC)
delete
Offline mvd71
#17 Posted : 26 December 2025 21:22:17(UTC)
Great that you found and solved the problem. Thanks for sharing the solution with photos.
Offline Kiko
#18 Posted : 26 December 2025 22:18:25(UTC)
Kiko
Hello mvd71
You're most welcome. I'm of the opinion that sharing solutions is important because some other unlucky bloke can have a similar problem and won't need to spend days chasing his tail.
Merry Christmas,
Andry
thanks 2 users liked this useful post by Kiko
This page was generated in 0.538 seconds.
