Offline Donb
#1 Posted : 20 December 2025 20:05:34(UTC)
Donb
Hi all
Merry Christmas! Greetings from Canada.
I pulled out my big boy 37990 for a little exercise on the layout, and noticed that I'm missing one of the number boards that sit at the front at the top and are illuminated. The illuminated number is 4013. Somehow over the past six months, it has disappeared, probably in a previous vacuum bag at the dump.Blushing
Any idea where I could get a replacement? The parts Page doesn't show a spare part # for it to no surprise, I gather one has to order the entire new body.
I will also send an email to M, but a reply will likely take months.
Cheers!
Best Regards,
Don
TFT ECOS, C track and Z scale, mostly DB/DR and SBB, SJ
Offline osoraku
#2 Posted : 20 December 2025 20:13:13(UTC)
osoraku
In the meantime, could you not fit a bit of cut film negative?
Osoraku
thanks 2 users liked this useful post by osoraku
#3 Posted : 21 December 2025 00:34:35(UTC)
Osoraku
It will take a bit more than that as the whole light fitting has fallen off, when you carefully compare it with the other side.
Offline dickinsonj
#4 Posted : 21 December 2025 01:15:37(UTC)
I am missing the top light on the rear of the tender, also lost a long time ago. I have pretty much given up hope of finding a replacement, but would love locate one if at all possible
Offline cintrans
#5 Posted : 21 December 2025 02:19:01(UTC)
cintrans
Aruba
Don
Is the foam in the wooden box still OK?
I found mine (at least the housing...) back in what used to be the foam liner that has turned all mushy
The number itself (decal) however I could not recover, so will need to create one on decal paper or something....
Jean-Pierre
This page was generated in 0.272 seconds.
