#1 Posted : 20 December 2025 11:48:26(UTC)
Hey!
I did checked locos manual and it shows no possible to take off the cover.
Also Trix shows same manual of the loco.
Why? Confused
Offline klarinettmeister
#2 Posted : 20 December 2025 16:11:49(UTC)
klarinettmeister
It says why in the manual of you read it.
Due to the complexity of the model, which results from
the reproduction with the greatest possible realism, we
recommend that the model be sent to Märklin Service for
additional service work
På grund av modellens komplicerade konstruktion, bero-
ende på dess extrema och verklighetstrogna detaljering,
så rekommenderar vi att modellen vid eventuellt behov av
service skickas in till Märklin Service.
thanks 1 user liked this useful post by klarinettmeister
#3 Posted : 20 December 2025 16:50:33(UTC)
Stand in same way in another models and you can take the cover off anyway.
And customer need doing service inside of the model.
Offline bph
#4 Posted : 20 December 2025 17:00:26(UTC)
A user over at Stummiforum describes it as a nightmare to open:
https://www.stummiforum.de/t239834f2-Br-als-Insidermodell-5.html#msg2878723
The locomotive is very nice, but had I known this in advance, I would not have bought it.
#5 Posted : 20 December 2025 17:16:34(UTC)
That is crazy!!! Blink
I don´t even see Schnittstelle so i suppose sound decoder are hidden under the roof (to follow the wires)?
LOL
Offline bph
#6 Posted : 20 December 2025 17:38:24(UTC)
LOL
According to the drawing, the decoder is hidden under the circuit board with capacitors etc.
#7 Posted : 20 December 2025 17:53:15(UTC)
You have right.
I can see it now. I do not understand with all those wires?
I did checked after another model BR 065 with catalog number 39651.
It shows similar same inside of the loco and how to unscrew the cover body.
Offline bph
#8 Posted : 20 December 2025 18:15:06(UTC)
You have right.
The dynamic smoke generators do require several wires (at least 6?), and then you have the wite and red running lights and the cab light.
This page was generated in 0.296 seconds.
