Offline revmox
#1 Posted : 19 December 2025 04:04:08(UTC)
revmox
4 months ago poor health forced me to move into an "over 55s lifestyle village" - which has actually turned out to be fantastic place.
I'm now ready to build a layout in half of the double car garage - that gives me about a 6.0 x 2.4 space to work with. I have obtained approval for a layout and also air conditioning of the garage which should happen on January 13th (Australia - its currently 42.6C outside - absolutely no chance of a white Christmas but did I spot two eastern brown snakes here last week as consolation - second most venomous snake in the world).
Where I'm stuck is a condition that says the layout cannot be permanently attached to any wall and must allow 500mm access to the walls OR be able to be moved by one person.
Being able to move the layout myself during construction and maintenance could be a great help and possibly allow for a larger layout because of the improved access.
Are there any recommendations on the best way to go? Is a movable layout just a really, really bad idea? I have access to LOTS of the tables as shown below - would they be suitable as a base to build on? The concrete floor is flat and very smooth so things should roll quite easily.
Cheers and thanks, Mark.
thanks 3 users liked this useful post by revmox
#2 Posted : 19 December 2025 07:33:49(UTC)
Wheels themselves are not the issue, usually most problems relate to the surface itself if uneven, or the wheels as risk of snagging as they might on carpet.
Many modellers do this for a variety of reasons. It may be worth looking at fitting some form of lock to clamp the wheels in place when required, or replace wheels with lockable style.
More importantly is the rigidity of the legs to prevent any movement or flexing.
The tables shown look to be ok, would the desk surface form the base or would you be building the layout to sit upon the desk(s)? Reason I ask is for access underneath for wiring etc.
As always, where there's a will, there's a way.
Offline revmox
#3 Posted : 19 December 2025 10:36:57(UTC)
revmox
Thanks cookee,
That desk is available in both locking and non-locking varieties - so good advice there - will make sure I get the right type. They are pretty rigid and the floor is very smooth and level.
I would bolt/screw 1200x600x9 or better marine ply sheets to the tables and lock them together with 50x25 or so runners. I used 2400x1200x16mm marine ply sheets for the last layout - all free and I thought it was a good idea but it was super heavy and damn awkward to handle. I'll go full digital over C track so should only need a few track feed points to run under the woodwork.
My doctors tell me to keep it simple and be realistic so I think something quick and simple will be the go.
Cheers and thanks,
Mark
thanks 2 users liked this useful post by revmox
Offline Copenhagen
#4 Posted : 19 December 2025 10:37:16(UTC)
Copenhagen
Great that you can still have a layout and be able to enjoy the hobby.
This thing about being able to get access to the walls is that on a regular basis or is it something that will rarely happen, but just a kind of standard requirement?
thanks 2 users liked this useful post by Copenhagen
Offline EB421
#5 Posted : 19 December 2025 11:07:46(UTC)
EB421
2.4-0.5=1.9m, Unless my math is wrong that gives you half a metre of scenic between the half metre gap and an R5 loop. Why not just leave a gap and use an island of fixed benchwork?
My whole board depth is 0.26m, so I see 1.9m as quite generous. ;)
thanks 1 user liked this useful post by EB421
Offline rhfil
#6 Posted : 19 December 2025 13:44:19(UTC)
rhfil
Not being very competent with wood construction I built a fairly large layout with pvc pipe and found wheels for the legs which made it mobile. None of the pvc is glued and it has lasted a number of years and a number of different layouts. The only cutting necessary was the pipe which is only available in 10' lengths.
#7 Posted : 19 December 2025 15:26:21(UTC)
Originally Posted by: revmox Go to Quoted Post
Thanks cookee,
Cheers and thanks,
Mark
I wouldn't worry about putting boards on top, but what I would do is use suitcase style latches underneath to hold the tables together so they move as a single unit. Something like these is what I am thinking of. That way when you move the layout the whole thing moves as a single unit, but can be broken down if needed.
If you are looking to do proper scenery over the joins between tables some duct or masking tape across the join will allow the scenery products to glue down. Another way is to have scenic breaks (mini tunnels?) at the joins so each table becomes a modular scene that could potentially be used standalone, in a manner similar to the N modular standard in the USA or the Fremo standard in Europe.
I would suggest thinking along the lines of the Fremo standard as you plan what you could do, and then modify that as suits you.
Offline wizardtrains
#8 Posted : 20 December 2025 09:55:41(UTC)
wizardtrains
Hi Mark
I have changed to a mobile layout due to arthritis and it’s the best thing I have done. I now have easy access to all parts of the layout. I am working in a garage with a concrete floor but I believe most hard surfaces would be suitable. The trick I found is to go for high quality castor wheels. The ones I purchased are super smooth and have a built in "jacking" system. See amazon: VEVOR Leveling Casters, Set of 4, 1100 lbs Total Load Capacity.
I believe them to be a good investment as I can move my 1.4m x 2.8m layout with one hand.
The table I built is rather sturdier than required but I use the lower section for storage.
Edited by user 22 December 2025 08:16:03(UTC)  | Reason: Not specified
thanks 2 users liked this useful post by wizardtrains
#9 Posted : 20 December 2025 16:33:04(UTC)
I once had a layout on platform trolleys that were easy to move around. It is important that the wheels are not too small.
And the foam boards used as layout base were easy to lift because of their low weight.
Offline Willem99
#10 Posted : 21 December 2025 00:24:33(UTC)
Willem99
Originally Posted by: wizardtrains Go to Quoted Post
Hi Mark
https://photos.app.goo.gl/xfqSa1zmsmPtEWx98
https://photos.app.goo.gl/MUgFiRqkgg1NMiSp7
That is sturdy enough to double as a shelter during an earthquake :)
Nice and clean work
Tim
Offline DB Fan
#11 Posted : 21 December 2025 02:56:19(UTC)
DB Fan
Hello
I have to agree with Alsterstreek. Try to use bigger casters (2”-4” diameter) with at least 3-4 locking once. Much easier to move it around on carpet and concrete then the once you pictured in your first post. Happy Model Railroading
Robert
thanks 2 users liked this useful post by DB Fan
#12 Posted : 21 December 2025 03:27:17(UTC)
you could also make your own modular system using those tables, so you can join them up in different combinations....
Offline revmox
#13 Posted : 23 December 2025 04:47:57(UTC)
revmox
Thanks for all the replies, advice and ideas. Sorry to take so long to acknowledge and reply to everyone - a couple of younger family members in and out of hospital.
Copenhagen - 500 mm wall access is required for any home maintenance and the local 8 year repainting cycle - it's obviously also great for building and layout maintenance - the plans that appeal to me frequently have hidden storage on that back edge and experience has taught me that the God of model railways ensures derailments and failures always happen in the least accessible part of a layout.
EB421 - 1.9m width might be available but on my last layout I found that my personal reach limit for any fine modelling work was 600mm - so any plan I consider will have a maximum board width of 1200mm and even then I found some corners a bit difficult - so I've been looking at some U shaped designs. Repeatedly ducking under to use some baseboard access hole just isn't a possibility for me.
rhfil - PVC is an idea I never would have thought of - I'd like to see some pictures.
kiwi - while lots of smaller modules don't appeal to me, the idea of being able halve the layout or even detach a smaller strategic section would turn many of the plans I have seen into a possibility. Great idea and one I'll think on very carefully.
Wizard - OK on using good wheels, the standard ones are 50mm diameter, the same as the office chair I use and it rolls fine - the local office supply place has ~80mm replacements that are cheap but I'm sure Amazon and Temu could beat that.
So wheels look like a good possibility if done wisely.
Thanks and Merry Christmas,
Mark
Offline rhfil
#14 Posted : 25 December 2025 19:38:22(UTC)
rhfil
rhfil - PVC is an idea I never would have thought of - I'd like to see some pictures.0.jpg
You don't need lockable wheels. The cups work fine.
thanks 3 users liked this useful post by rhfil
Offline revmox
#15 Posted : 25 December 2025 20:18:38(UTC)
revmox
rhfil - PVC is an idea I never would have thought of - I'd like to see some pictures.[/quote0.jpg]
Thanks, very clever and light weight. An idea right outside the traditional box, I'm impressed.
Offline rhfil
#16 Posted : 25 December 2025 20:51:18(UTC)
rhfil
Thanks. Some of the fittings had to be special ordered but were readily available at no extra cost through Home Depot and Amazon. Got to love Home Depot's special order pick-up service. Not sure what is available down under. The entire thing is moveable with one finger.
Online xxup
#17 Posted : 25 December 2025 21:37:50(UTC)
We have Bunnings! All that plastic looks fairly standard to me. It is a great idea and it would be very light weight. I would still plonk some wheels on those legs. You might need some bracing in one or two places though. Cool
#18 Posted : 25 December 2025 23:00:42(UTC)
Although my layout is mobile, when I started building my layout I never thought I get old and some of the modules (2400mm x 1200mm) seem to get heavier as I got older, I think you've got 2 options with PVC pipes, 1 for reticulation and 1 for plumbing, I think it a great idea, I go along with Adrian, a few braces for double strenght, I don't think you would have to glue them together, the horizontal pipes can be secured with a selftapping screw or 2 being drilled into it so it doesn't fall apart.
Offline rhfil
#19 Posted : 26 December 2025 02:17:35(UTC)
rhfil
It does have wheels and is very stable. Around ten years old already. I cut the pipes with a chop saw but a pvc hand saw would have worked.
Offline Roland
#20 Posted : 26 December 2025 17:10:19(UTC)
Roland
Views messages in topic : 343
I decided to build my layout on wheels in order to maximize its size in the room. My layout can be moved in any direction if access to a side is needed. As has been mentioned, large wheels are the way to go. I went with 4" wheels and the layout can be moved quite easily despite the basement floor not being perfectly flat.
EDIT: I should mention that I originally went with smaller 2.5" wheels but was unhappy with them and eventually replaced them all with 4".
Märklin H0 for sale
My Layout Build | Märklin CS3+ | K-track | Merkur | Viessmann | LDT | iTrain | Rolling Stock: Märklin, Roco, Piko, ESU/Pullman | Modeling primarily DB/DB AG EpIV-VI
thanks 2 users liked this useful post by Roland
This page was generated in 0.746 seconds.
