Offline mb300e4m
#1 Posted : 25 November 2025 22:31:28(UTC)
mb300e4m
Hello all,
I am assembling a small C Track layout for Christmas so that I can show off some of my new goodies to visitors. I am using SCARM for the design and find there is a gap in the track in one area. It may be a shortcoming with SCARM or it actually may be so when I lay the track.
Anyone have any opinions on this?
Thanks in advance,
Peter B. in sunny Florida.
[img]http://[/img]Xmas Tree Loop 01.jpg
Edited by user 26 November 2025 14:39:09(UTC)  | Reason: Not specified
Peter B.
In Sunny Florida most of the time.
Marklin, Trix Express, Trix Twin, Fleischmann, Liliput, Hornby Dublo, and Others, 2 & 3 Rail, AC, DC and Digital, Course Scale Wheels & Fine, 1935 to 1960s usually.
thanks 1 user liked this useful post by mb300e4m
#2 Posted : 26 November 2025 00:05:57(UTC)
Assemble it and see if it joins up. Use the length of c track that works.
Offline EB421
#3 Posted : 26 November 2025 01:30:36(UTC)
EB421
Try this approach for your crossovers:
A variant of the track plan.
As you can see from the added crossover at the top (only there to make the point) this lines up properly with C-Track geometry and has simple 229's on all sides.
thanks 1 user liked this useful post by EB421
#4 Posted : 26 November 2025 05:59:36(UTC)
To resolve your issue, the curve with the curved switch should be aligned as follows (rotate second photo 90 degrees to the right to correspond):
Screenshot 2025-11-25 at 11.58.22 PM.pngScreenshot 2025-11-25 at 11.58.57 PM.png
Once done this way, the tracks on the opposing side should properly line up with the outer track using R2 and the inner one using R1 tracks
By correctly using the 24230 and 24130 as indicated, the tracks should maintain the separation required for R1 and R2 and the spacing at the top and bottom should be identical.
Offline Copenhagen
#5 Posted : 26 November 2025 13:54:28(UTC)
Copenhagen
I haven't opened up my PC and Scarm but another way could be experimenting and fiddling with what smaller C track straight pieces, which there are several of, could fill the gap.. maybe even omitting the top 229 in favour of another piece. Even if the end result will show a small gap or be too big there will be enough flexibility to make it fit.
Offline mb300e4m
#6 Posted : 28 November 2025 23:19:53(UTC)
mb300e4m
I tried a number of different straights and found ones that would fit, but to complete the layout i.a.w. the diagram I'll need to buy a few more pieces. So eBay here I come again.
Peter B. in Sunny Florida.
Peter B.
thanks 3 users liked this useful post by mb300e4m
Offline mb300e4m
#7 Posted : 01 December 2025 17:08:41(UTC)
mb300e4m
What is the difference between 24230 and 24230 B curved track sections?
Peter B in sunny Florida.
Peter B.
#8 Posted : 01 December 2025 17:20:54(UTC)
Blister pack packaged for start up.
#9 Posted : 01 December 2025 19:10:52(UTC)
In my earlier post, I showed how you needed to replace one pair of 24230 with 24130s in accordance with the track plan for the C track curved switches. Once you have done, this, the track sections on the top and bottom of your layout will match and you will be able to use the corresponding track parts equally for both ovals. By using the 24230 instead of the called for 24130, you have thrown your trackage out of alignment, yet you insist on trying to fix the solution with straight tracks when it is the curved sections mentioned that need to be swapped out.
Happy December!
This page was generated in 0.342 seconds.
