Offline Alex H
#1 Posted : 25 November 2025 20:02:52(UTC)
Alex H
I am building a new layout using the Marklin C track.
I was wondering what the consensus is on whether to solder my power and feedback cables to the rail tabs, or just to use spade slide connectors onto the tabs
thanks 1 user liked this useful post by Alex H
#2 Posted : 25 November 2025 20:11:43(UTC)
Hi Alex
Definitely on the ground part, you can solder all connections because you don't need ever to disconnect
On the B part the best is to have zones of 2 meters long or so - insulated on both sides so that ONLY ONE wire feeds the section and uses a connector. This is to locate rapidly the zone were a short circuit is located.
An alternative solution is to do exactly as above except that INSTEAD of the connector, you install a 5W 12 V lamp as used in cars. That way when a short happens, the lamp of the shorted zone will lit.
This page was generated in 0.301 seconds.
