Offline garben
#1 Posted : 13 November 2025 20:21:19(UTC)
garben
I have set up in Engine Operations to automatically turn on certain functions, light, sounds etc. When I'm done for the evening running the trains, and before I shut down, is there a way to shut off all train functions? This way when I start up the next session, everything is off?
Thanks!
Norbert
Offline pederbc
#2 Posted : 13 November 2025 23:43:15(UTC)
pederbc
easy!
create a "push button", and under "Operations", select "Switch Functions of all Vehicles", Select which function(s) to switch on/off.......
Have a nice weekend, Peder
Offline garben
#3 Posted : 14 November 2025 01:47:49(UTC)
garben
Prefer,
Perfect! That’s a great idea! Thanks so much.
Offline blid
#4 Posted : 14 November 2025 13:17:39(UTC)
blid
I designed two functions for every engine. One for starting up and one for shutting down with functions available for that particular engine. Then it would only require the shut down function per engine in Peder’s solution.
Offline pederbc
#5 Posted : 14 November 2025 16:40:12(UTC)
pederbc
I have created ”virtual” functions for light, sound, long horn, short horn, interior light and drivers cabin light. Then for each engine i map these to the engines actual corresponding function. Then I can use these functions in general macros etc that will then work on any engine and also on interior lights in waggons.
Peder
Offline Kiko
#6 Posted : 16 November 2025 06:39:01(UTC)
Kiko
Hello All,
I don't think that there's a need for all of this. In TrainController, all you have to do is assign decoder functions (i.e., horn, bell, whistel, etc.) to function keys when you create a locomotive. After that, when you specify in a particular block that the "horn" should sound, then all locos travelling through that block will activate their horn -- no matter what function key that horn is assigned for that loco.
Andry
Offline pederbc
#7 Posted : 16 November 2025 09:26:59(UTC)
pederbc
That’s exactly what I meant! On some engines the horn is on F2 and another on F3. By creating a ”new” horn function and assign this to the actual function key then this will work anywhere you use it.
Offline blid
#8 Posted : 16 November 2025 13:15:54(UTC)
blid
Some engines have horns some have whistles. That’s why I made a function for long signal and one for short signal. Engines with no sound flashed the lights.
Offline blid
#9 Posted : 16 November 2025 15:36:43(UTC)
blid
Maybe it is worth pointing out that you can include almost anything in an engine function button. I had many of my engines store in dedicated places on a parking deck. A function button turned power on for that siding, run the startup function and started the schedule to bring the train up to a station. Another button brought it back down.
Offline Kiko
#10 Posted : 16 November 2025 19:17:15(UTC)
Kiko
Maybe I don't fully understand, but there's no need to create any "new" function. For example, my loco BR17 (LokSound) has the whistle on F2 and my BR56 (MFX) has the whistle on F3 (see pics). On my layout, when these locos approach a bridge, the whistle sounds because in TrainController I have an action item defined in the block before the bridge that says "sound whistle".
Note 1: All my ESU LokSound equipped locos have consistent function assignment because I like to have things organized -- easier to remember. However, Marklin factory equipped MFX locos are not so nice. Marklin does not adhere to an easy to remember scheme but assign functions whichever way they feel like. Angry
Note 2: Other issues with functions is that some functions like whistles, horns and bells are sometime defined as "On/Off" and other times as "Pushbuttons". To address the inconsistencies, I created macros in TrainController for these functions. These macros turn a function ON for a specified number of seconds, and then turn the function OFF. This ensures that both the "ON/OFF" and the "Pushbutton" activations are reset when the function terminates. So to clarify, in TrainController, the actual action item defined in the block before the bridge is "activate macro whistle".
Andry
Offline pederbc
#11 Posted : 16 November 2025 23:06:46(UTC)
pederbc
My reason is that I don’t want to change the original functions for each engine. Therefore I created new functions for the type of functions I want to control via TC.
Peder
Offline Kiko
#12 Posted : 16 November 2025 23:47:04(UTC)
Kiko
Hello Peder,
Why would you need to change any original functions in any of your locos? In my example above, I did not change function mapping in the Marklin BR56 MFX loco. All I need to do is assign TrainController names to loco functions -- refer to my screenshots above. As long as you assign TrainController recognizable names to decoder functions, TrainController uses those names to activate specific functions -- i.e., these names act as assigned variable.
Please note that TrainController "recognizable names" are taken from the TrainController "Library" and will depend on your command station. When configuring TrainController and selecting your command station, the command station locomotive database is imported into TrainController. That's where all the functions of all your locomotives are mapped to TrainController.
I'm not sure if I'm making a lot of sense, but I hope this helps.
Andry
Offline garben
#13 Posted : 18 November 2025 16:25:04(UTC)
garben
easy!
Hi Peder,
Well it sounded easy but I could not get it to work. I'm sure I'm not doing something correct.
I did not see the "Switch Functions of all Vehicles" for starters. I created a Macro as a test, added the light function and sound function and indicated that they should be off when the push button is in the off position, but nothing happens. Would you happen to have step by step setup you could share for me to try?
Thanks in advance!
Norbert
Offline pederbc
#14 Posted : 18 November 2025 20:55:32(UTC)
pederbc
@Kiko: I think we have different ways of using functions, and will leave that discussion now.
@Garben:
here's a picture of how to use the operation.
In this example, by pressing the button, the 2 operations will be executed on all engines active on the layout.
Try it, Peder
Offline garben
#15 Posted : 18 November 2025 21:07:47(UTC)
garben
@Garben:
Try it, Peder
I will try tonight and report back, lol. Thank you very much!
Offline garben
#16 Posted : 18 November 2025 23:25:07(UTC)
garben
@Garben:
Try it, Peder
Found it and works great. Picture worth 1000 words. Thanks again, appreciate it.
Norbert
Offline blid
#17 Posted : 19 November 2025 13:19:41(UTC)
blid
It works for the ”home made” functions as well. I also designed symbols and added them to the library.
This page was generated in 0.404 seconds.
