#1 Posted : 10 November 2025 17:15:50(UTC)
I have some yellow 2-axle tank cars marked DANZAS
The one on the left is item 46422 and has close couplers. The one on the right has Relex couplers and the simpler walkway on top. I suspect it may be a commercial print run, can anyone identify it? Rail companies: SBB CFF FFS Zurich
Offline rbw993
#2 Posted : 10 November 2025 17:36:26(UTC)
rbw993
Dale,
I think it is a ROCO 76780. Found one on E-Bay.
Roger
#3 Posted : 10 November 2025 17:44:11(UTC)
no, the Gattungsschild is different.
The ROCO model does not have the small text below the blue DANZAS text, different railing too. Based in Basel.
It is a Märklin model.
Offline Unholz
#4 Posted : 11 November 2025 08:22:37(UTC)
Unholz
Perhaps something like this one, if the printed road number corresponds: https://www.modellbahn-r...sselwagen-db-danzas-ovp/
Offline Jimmy Thompson
#5 Posted : 11 November 2025 13:29:54(UTC)
Jimmy Thompson
Here is a Jimmy SWAG (Silly Wild A-- Guess)Unsure
Could the one with the less elaborate walkway be a special Primex (as it would still have "Märklin" imprint on the underframe) imprint as it also does not appear to have data printing on the frame??
Just my 2 pf.ThumpUp
p. s. I can not quite make out what the small text under the "S" says
Jimmy T
Dr Dirt's Rule #1 and
#6 Posted : 11 November 2025 18:25:15(UTC)
No, that is the one on the left with close couplers...
#7 Posted : 11 November 2025 18:28:44(UTC)
It's a good thought.
The 4440 tank car has been used for numerous commercial print runs, so I think that is probably what I have.
I don't have the Kolls special catalog that covers them.
#8 Posted : 12 November 2025 00:53:08(UTC)
As far as I remember, the Primex tank car was based on the original older Maerklin design with flatter chassis and metal railings, ladder and top rails without the round part at the top of the ladder
MC
#9 Posted : 12 November 2025 01:07:36(UTC)
I believe it is most likely that this car is either from a start set or was released as a Swiss only model under the number 4441-9XX
This page was generated in 0.327 seconds.
