Offline Paul gRAVER
#1 Posted : 03 November 2025 17:56:12(UTC)
Paul gRAVER
I am wiring a Marklin HO layout using old style track and K k83 decoders. I cannot get the decoder to change the turnout position. The turnout light goes on, so I am guessing power is reaching the turnout. I tried another keyboard and have reset the keyboard and decoder switches. Other than lighting the turnout light, I get no response from the turnout or a nearby uncoupler. Any ideas?
Offline mvd71
#2 Posted : 03 November 2025 18:53:49(UTC)
Try connecting the decoder output to another turnout to check if the problem is the turnout or the decoder.
Offline RudiC
#3 Posted : 03 November 2025 20:21:36(UTC)
RudiC
Does the turnout motor move at all, e.g. when connected (for a split second) to the power supply?
A picture of your wiring might help.
Rüdiger (Rudi)
Offline BenP
#4 Posted : 03 November 2025 22:21:39(UTC)
BenP
Reset to what? Keyboard has one default setting (forgot which of 4 is on). K83 has 8 dip switches. What setting do you use for k83, as first keyboard allows only 1-16.
Yellow is accessory power; blue wires (red green) are switching ground connects.
Ben
Ben van der Pluijm--
#5 Posted : 04 November 2025 07:37:48(UTC)
Yep.
Never forget that older decoders will not work if red ("B") and brown ("0") wires are swapped.
Lights at the turnouts indicate there is power for the lights.
But for the solenoid to operate, you have to also close a circuit through the k83 decoder
#6 Posted : 04 November 2025 15:23:22(UTC)
My keyboard was acting up so I sprayed some contact cleaner/Deoxit on the buttons and it's ok now.
Offline Paul gRAVER
#7 Posted : 06 November 2025 21:39:22(UTC)
Paul gRAVER
Thank you. I tested the switch bypassing the decoder. Worked fine. I tried another decoder. No luck. Tried another keyboard. Resent the dip switches on both keyboard and decoder. Tried another decoder on an uncoupler track. Nothing. Then I noticed I had accidentally put a brown connector on the red wire and a red connector on the brown wire. This meant everything I tried was mis-wired. I reversed the pins -- red to red, brown to brown and it corrected the problem. I am not color blind but apparently I am careless. A good lesson in frustration!
thanks 1 user liked this useful post by Paul gRAVER
Offline Paul gRAVER
#8 Posted : 06 November 2025 21:45:34(UTC)
Paul gRAVER
Yep.
You are exactly correct! I just proved that by accidentally putting a brown connector on the red wire and red connector on the brown wire. Nothing works with the K83 mis-wired. Thanks for the suggestion!
This page was generated in 0.421 seconds.
