Offline gary664
#1 Posted : 01 November 2025 19:29:04(UTC)
gary664
Hello, I recently acquired this Marklin z “fun starter set” but I can’t really find any information on this product itself. I know 81520 is the general item number for the small starter sets, but I can’t find anything about 81520.000.
My guess is it was just a promotional item for Mercedes of some sort?
Any info on the product would be appreciated.
thanks 1 user liked this useful post by gary664
#2 Posted : 01 November 2025 21:33:35(UTC)
I guess it is a promotional version of the base 81520 set (for which there was an add-on set 81950). I take it there is just a Br89 and a single Mercedes labelled boxcar in your set.
Offline gary664
#3 Posted : 02 November 2025 01:49:38(UTC)
gary664
Correct, that’s exactly what’s in the box.
Offline Zme
#4 Posted : 02 November 2025 04:35:39(UTC)
Zme
Hello hope all is well
According to Z-Freunde-International, this is a special advertising set (werbemodelle)from 2002. While this is common today, it was unique at that time when each side of the refrigerator wagon had a different image. It is interesting the package has the mark (81520-000) you mentioned while Z-Freunde-International indicates the number as 81520-016. Looks complete.
Z scale train sets such as this are of special interest to collectors because they appeal to z collectors and Mercedes owners too.
There is no indication of the quantity of these sets, but similar sets have as few as 100. Since this set does not indicate the quantity, I would assume it was probably produced in a quantity of 3000 worldwide The set was likely available at the dealership at the time. Now you rarely see it in the secondary market and it should command a higher price but I cannot estimate a value.
A nice and fun find. That Br 89 should have a five pole motor for smooth operation I hope it works. Is it marked 89 2002? If it is, it likely belongs to this set. Sweet! I hope you got a bargain.
Take good care.
Zme
Offline gary664
#5 Posted : 02 November 2025 15:58:59(UTC)
gary664
Take good care.
Zme
Awesome. Thank you for all the info! I swear I couldn’t find any info on this set anywhere.
Yes, the loco has marked 2002. And I think I got a fair deal in my opinion, $100 usd all in. Pretty good for a new set. It looks as if this set has never been put together. Now just need to test the loco.
thanks 2 users liked this useful post by gary664
Offline Zme
#6 Posted : 03 November 2025 04:36:25(UTC)
Zme
Hello, hope all is well.
Please remember, this set is over twenty years old and from what you described, it was hardly used.
It is not uncommon for the oil in the locomotive to harden (Hardened Oil Syndrome)and may lockup the drive wheels. Be careful about apply power in one direction for an extended period if it is locked up or you might end up with a burned out motor.
You might consider giving the locomotive a cleanup before attempting to run it.
This locomotive is not easy to work on if the motor needs replacement. It is not a self-contained motor and replacement involved removing the armature from between the frame itself. You may search these forums for tips on cleaning and maintenance of Z scale locomotives.
You can search the internet or YouTube to find helpful information to do it yourself.
Take good care. Best wishes.
Zme
Edited by user 03 November 2025 17:52:02(UTC)  | Reason: Not specified
Offline wildstix
#7 Posted : 05 November 2025 10:12:02(UTC)
wildstix
Indonesia
Take good care.
Zme
If the loco isn't moving when you test it, I posted about cleaning that loko in Marklin Indonesia collectors group, here. Maybe it can help should the loco not moving smoothly.
All captions are in Indonesian but you can translate it easily nowadays.
Update: I stiched my fb post into one video. Check it out here
Edited by user 07 November 2025 12:44:39(UTC)  | Reason: update on the link
Oka aka W. Kapriandi
Märklin Z scale (mini-club) purist but not a modeler!
thanks 2 users liked this useful post by wildstix
Offline Zme
#8 Posted : 06 November 2025 16:26:52(UTC)
Zme
Here is a parts diagram for this locomotive should you discover you need to work on this one.
https://www.marklin-users.net/up.../Zme/7143_Br 89 8800.pdf
Take good care.
Zme
This page was generated in 0.329 seconds.
