Offline Kristaki
#1 Posted : 27 October 2025 10:44:12(UTC)
Kristaki
i have also another issue...
the 7190 with a light on the M track i have it connected to the c and m convert gleis to be on the layout connected..
I did this connection i connect the 7190 yellow cable on the 6611 transfo and the 6611 transfo is connected to the layout but the bulb dont light up... i wonder what i did wrong here has B and O is connected also to the 6611 transfo has a test even on a text m with B and 0 and hte 7190 dont light up i tried with few ones.. no result i doubt they all dead the bulbs or on the C and M track to actual digital layout and with the 7190 connected also dont work
is the 7190 not enable to work on a Digital?
i wonder has even has told babove with a M 4 rails and the 7190 and all this connected to thge 6611 not owrking anyone has a clue here for me maybe ty
thanks 2 users liked this useful post by Kristaki
Online marklinist5999
#2 Posted : 27 October 2025 11:31:44(UTC)
Try only connecting it to M tracks and not the C to M transition track because the terminals are different and confusing. Does it light up with the wires connected to only your 6611 trafo and no track? My old analog signal works on my digital layout. It's just a light bulb and a solenoid.
The store should be able to help you with this and more because you are a beginner. My first dealer did. He was from Germany.
Later on, if you have any old analog M track turnouts, you can get M 83 decoder which is mfx and connect to the track for power and digital from the MS 2. You could then program the M 83 decoder in MS 2 to operate turnouts and signal 🚦
Offline Kristaki
#3 Posted : 27 October 2025 12:50:35(UTC)
Kristaki
Works with power locgoes only with m track but this bulb dont light up
thanks 1 user liked this useful post by Kristaki
#4 Posted : 27 October 2025 14:50:34(UTC)
Bad bulb perhaps then? That's why I asked you if you tried just the yellow bulb wire and brown ground wire to the transformer.
Offline Kristaki
#5 Posted : 27 October 2025 14:56:00(UTC)
Kristaki
OH YEAH IS FIXED WAS THE I HTINK TO SCRATCH A BIT THE COPPER NOW WORKS THE CONECTIONS WERE FINE I WILL USE THESE 8 ON THE TRASNBORDER 7294 I HAVE TO VERIFY THIS ONE ALSO THEN BE FINE:)
Offline Kristaki
#6 Posted : 27 October 2025 15:33:37(UTC)
Kristaki
ALL WAS IN BOXES SINCE 45 YEARS SO IMAGINE.. BUT WAS GOOD TAKEN CARE
Offline 1borna
#7 Posted : 29 October 2025 21:23:47(UTC)
1borna
Croatia
Over time, all metal sheets oxidize more or less depending on the conditions they are stored in, so the contact is poor or
non-existent. A little sanding with fine grit (1,000) will clean it up, and it is a good idea to use contact spray.
thanks 2 users liked this useful post by 1borna
This page was generated in 0.270 seconds.
