Offline applor
#1 Posted : 23 October 2025 00:10:01(UTC)
applor
Hello all,
I have a MS2 which I normally leave connected to my CS2, it works fine. I need to connect the MS2 to my 60113 trackbox to reset MFX registration on two locos.
However the MS2 powers up and stays stuck on 'Marklin' on the display and nothing else. I am assuming the trackbox is faulty.
Could this be related to firmware by chance? My MS2 is running current firmware via CS2 update but can a 60113 / 60116 trackbox get updated?
Offline osoraku
#2 Posted : 23 October 2025 02:26:40(UTC)
osoraku
Dear Applor -
First check the pins in the MS2’s DIN connector. Bent ones can cause strange behaviour.
Osoraku
thanks 1 user liked this useful post by osoraku
#3 Posted : 23 October 2025 07:13:18(UTC)
Yes. When the MS2 passes the Märklin screen and becomes alive, it will have a menu entry to update the track box.
It could help to delete some files from the MS2 file system. I'm not sure if this can be done while the MS2 is connected to the CS2, but might be worth a try.
#4 Posted : 24 October 2025 01:55:07(UTC)
It could help to delete some files from the MS2 file system. ...
Related...
Observing the screen during the update , there is a "defrag" step
Offline applor
#5 Posted : 24 October 2025 07:01:13(UTC)
applor
The pins must be fine because its the exact same cabling as used with my CS2, which works OK.
After yesterdays updates via CS2, I connected the trackbox again and this time it asked me to update.
Great sign!
However after pressing yes it jumped to 9% progress and has not changed for an hour.
I dare say there is no way out of this.
#6 Posted : 24 October 2025 09:49:56(UTC)
This statement is incorrect/incomplete. Although it may not be related to your main problem
There are two pairs of power pins that Maerklin have used in a manner that allows a MS2 to work off both a CS2 and MS2 (Native and with a 60122 HUB). The 60122 MS II Hub will (with its 10 pin plug) will physically plug into a CS2, but will not operate.
The symptom of lights on (power) but no one home (brains) is most likely to be one of the CAN bus pins being bent.
Given that you have indicated there are some brains, because you indicate "...this time it asked me to update...." there still leaves a possibility that the pins are bent such that the connection is not good and may loose contact with movement.
Offline applor
#7 Posted : 24 October 2025 12:52:34(UTC)
applor
If one of the CAN pins was bent, I wouldn't be able to use or update the MS2 when it is connected to the CS2. Unless I am mis-understanding something?
Offline rhfil
#8 Posted : 24 October 2025 18:32:58(UTC)
rhfil
It appears that you are unable to update the MS2. A bent or missing pin on the cable would be easy to ascertain with a visible inspection.
Offline applor
#9 Posted : 25 October 2025 04:36:36(UTC)
applor
No you didn't read my posts properly. The MS2 has been updated by the CS2 without issue. It was only stuck with the 9% when the MS2 tried to update the 60113 trackbox.
And as already explained, I am using the exact same cable/connectors as the CS2 to MS2 as the Trackbox to MS2, so its not a cabling issue. The CS2 and trackbox have the same 10 pn DIN connector socket, I am simply swapping from one box to the other.
#10 Posted : 25 October 2025 15:02:43(UTC)
What is the latest version at your CS2?
It could be that you track box cannot use the latest version from your CS2?
Try to get track box 60116 instead but I cannot promise you if this will work.
#11 Posted : 26 October 2025 17:39:16(UTC)
I updated my 60113 track box to the latest version without issues. So it works theoretically.
If it turns out that the 60113 in question is FUBAR, a new 60116 could be the solution.
But I'm not sure if it is time to give up already.
Offline applor
#12 Posted : 11 December 2025 10:35:12(UTC)
applor
I received my new track box today.
It immediately upgraded to latest version no problems, booted OK and registered MFX loks OK.
So just confirming the old one was indeed faulty as I suspected.
thanks 4 users liked this useful post by applor
This page was generated in 0.466 seconds.
