Offline Zazza
#1 Posted : 22 October 2025 11:23:02(UTC)
Zazza
hello
I'm trying to design a 3 tracks parallel curve to fit my layout into may garage.
the reason why I want to stick with 24230 and not go to 24130 is to make sure that steam loco will be able to run.
the problem I face is that by using rail modeler I can't find a good option to design it.
has some of you already gone through the same issue and has any suggestions?
thanks
thanks 1 user liked this useful post by Zazza
#2 Posted : 22 October 2025 12:30:39(UTC)
If the tracks have a spacing of 77 mm, you can use 24077 to pad some tracks.
You could use a mix of R2 and R3 (24230 and 24330) to reduce the number of 24077 track pieces.
R4 was made for a track spacing of 64 mm, but result may look better with a mix of R2, R3, and R4.
#3 Posted : 22 October 2025 13:44:53(UTC)
Yes exactly as HO Tom said. I ordered a variety of small radii and straight tracks too. I didn't want to venture into cutting C track.
Offline Zazza
#4 Posted : 22 October 2025 14:22:32(UTC)
Zazza
is this what you're suggesting?
I can't make it even on the straights :-(
Offline rbw993
#5 Posted : 22 October 2025 14:39:23(UTC)
rbw993
Z,
I think it will work with two 24077 on the mid and outer curves.
Roger
Offline BenPerr
#6 Posted : 22 October 2025 14:40:31(UTC)
BenPerr
I think that the under is what was suggested, basically using 24077 for the spacing of the 24230 to keep everything 'kosher'.
Note that the 24611 and 24612 switches are just there to establish the 77.5mm separation between tracks.
Also, what steam locos are not able to handle the 24130 radius??
thanks 3 users liked this useful post by BenPerr
#7 Posted : 22 October 2025 16:02:52(UTC)
Here's an attempt using R2 only, adding 3x 077 for the centre track and 7x 077 for the outer track:
Here's an attempt using R2 and R4, adding 3x 077 to the outer track:
Offline Zazza
#8 Posted : 22 October 2025 17:07:52(UTC)
Zazza
you saved my day!
may I ask which software are you using?
Offline BenPerr
#9 Posted : 22 October 2025 17:14:37(UTC)
BenPerr
thanks 1 user liked this useful post by BenPerr
This page was generated in 0.394 seconds.
