Offline Fille
#1 Posted : 18 October 2025 20:12:10(UTC)
Fille
Hi all.
My name is Felippe and im about to order my first modelrailroad starterset. Märklin digital H0.
This will be my first time with modelrailroading, im a scale modeler And i wanted to do something more interactive.
Im playing around with SCARM and trying to learn it and But i have some errors. some pieces dont line up exactly.
Thank you.
Offline rbw993
#2 Posted : 20 October 2025 15:17:39(UTC)
rbw993
Hello Felippe,
Welcome to the forum. I used SCARM to design my layout, Immensee, also a topic on the forum. Don't worry about small misalignments. There is enough "play" in the track that will allow assembly.
Roger
Offline Fille
#3 Posted : 20 October 2025 17:48:45(UTC)
Fille
Thank you Roger. This was driving me crazy 😃🍻
I will check out your thread. its great to see how people build and design their railroads.
Offline Copenhagen
#4 Posted : 20 October 2025 22:33:58(UTC)
Copenhagen
While some misalignment still can be made to fit without problems I'm a bit worried about the gaps on the left side of the layout. I have done a lot of fiddling with scarm to make ends meet in creating and changing parts of my layout, and it often took quite a lot of experimenting with all sorts of small bits and pieces to get a good fit and a nice looking shape.
Sometimes you succeed with almost impossible things. Sometimes you have to reevaluate everything and come up with something different.
thanks 2 users liked this useful post by Copenhagen
Offline Fille
#5 Posted : 21 October 2025 14:43:19(UTC)
Fille
Thank you. I will have a check to see if i can get the gaps alittle smaller. Atm im playing around basicly adding a wye and a reverse loop to the starter pack. My thought process was that to have the train able to take some different paths. Writing this i just realised i might not need the wye to make the train go left or right in the right area...
thanks 1 user liked this useful post by Fille
Offline Copenhagen
#6 Posted : 21 October 2025 16:05:58(UTC)
Copenhagen
There is a lot of thinking and planning going on when making plans for a layout. One sits and looks at the picture and imagine how the trains will run from place to place and in what directions. Having a wye looks great (I only have a couple of reversing loops incorporated myself, one of them to be able to back train consists into staging tracks). The loop on your left side could be simplified if only a single track led into it. Lots of fun involved in the planning phase.
Offline Fille
#7 Posted : 21 October 2025 17:25:21(UTC)
Fille
Good points. Will look into it. The plan is to move the loop further down on left side as i get more experience and track and later on close the area at the bottom so i can have a train run around the whole layout but to spare a square hole in the middle to be able to reach things.
where the right leg ends is at a door but ive got like a door width and then an aditional meter of the room. (my english aint the best) So i have still room to stand and run the layout.
Offline Fille
#8 Posted : 01 November 2025 12:22:23(UTC)
Fille
So me and the kids have been having a blast with the set 😃
Was so easy and fast to setup.
Offline BenP
#9 Posted : 01 November 2025 15:28:54(UTC)
BenP
Uses SCARMs measuring function for exact gap length. Track calculator tells you what pieces needed.
https://cabin-layout.mix...ngth-calculator.html?m=1
Ben
thanks 2 users liked this useful post by BenP
Offline Fille
#10 Posted : 01 November 2025 15:41:22(UTC)
Fille
Oh thats perfect 🍻
Thank you
This page was generated in 0.339 seconds.
