Offline Adrian666
#1 Posted : 12 October 2025 17:02:08(UTC)
Adrian666
Romania
Hi guys,
Please assist with this problem: I cannot start this locomotive, was able to read it with CSS3 but the loco doesn't run, no lights, but the wheels are moving.
I attached a video!
I also tested another loco and it works, wanna rule out any issues with the track.
This was an online order,I don't want to open the loco as I will return it if it doesn't move.
Let me know if I'm doing anything wrong
Offline rhfil
#2 Posted : 12 October 2025 22:40:06(UTC)
rhfil
Apparently it is a fx decoder so should have a MM address.
Edited by moderator 16 October 2025 00:49:59(UTC)  | Reason: Deleted unnecessary comment
Offline Chris6382chris
#3 Posted : 12 October 2025 23:12:19(UTC)
Chris6382chris
That is what this is forum is for. People ask questions and people offer suggestions and solutions. As a result, people "learn how to use the equipment".
Edited by moderator 16 October 2025 00:50:49(UTC)  | Reason: Removed unneccary comment from within the quote.
thanks 3 users liked this useful post by Chris6382chris
Offline Adrian666
#4 Posted : 12 October 2025 23:25:01(UTC)
Adrian666
Romania
Thanks for replay. I also tested on MM.... That wasnt the issue
Long story short , the loco has a lever to change how it gets electricity
I managed to make it work. But wasnt due to lack of equipment knowledge.
thanks 2 users liked this useful post by Adrian666
#5 Posted : 13 October 2025 03:20:03(UTC)
Chris6382chris
Congratulations on getting the engine running. I did see the level under the locomotive, assuming that was to switch it from getting track power to overhead catenary power? Again, congratulations.
thanks 2 users liked this useful post by Chris6382chris
Offline rhfil
#6 Posted : 13 October 2025 03:59:53(UTC)
rhfil
The lever is part of the loco and the loco is an equipment. Did the loco come with a manual? Your video shows you registering a loco and reading the address of a dcc decoder. Analog is much simpler.
Offline Adrian666
#7 Posted : 15 October 2025 07:17:32(UTC)
Adrian666
Romania
thank you! the lever was a switch between track power and catenary. This was absolutely new to me!
thanks 1 user liked this useful post by Adrian666
This page was generated in 0.244 seconds.
