Offline Alex H
#1 Posted : 06 October 2025 19:48:43(UTC)
Alex H
Hi. I am getting to the point where I will shortly be starting to lay track on my new layout. I'm using the Marklin C track.
Once I have crimped the wire to the flat sleeve connector, I am wondering if it is worth running a small amount of solder over the joint, before I connect the cable to the track?
Members thoughts much appreciated.
Offline 1borna
#2 Posted : 06 October 2025 19:58:24(UTC)
1borna
Croatia
I don't think there's a need because it's an area that isn't exposed to dust and won't be constantly moving to cause the wire
to fall out of the connector?
thanks 1 user liked this useful post by 1borna
Online rhfil
#3 Posted : 07 October 2025 00:39:09(UTC)
rhfil
If you are not going to make any changes to the layout it is one way of ensuring a good connection.
Offline dickinsonj
#4 Posted : 07 October 2025 00:58:48(UTC)
If I know the wiring won't be changing I always do that. I don't know if it is absolutely necessary but it is easy to do and I agree that it ensures a good connection.
Offline DB Fan
#5 Posted : 07 October 2025 02:49:31(UTC)
DB Fan
Yes I definitely would do that. I’m in the middle of doing that since I had the ground slip off during running trains on 1 connector and had a short. Always felt they are a little loose and tried to squeeze them to have tighter connection but it still came loose. But that is just my opinion. Happy Model Railroading
Robert
Offline Aussie Susan
#6 Posted : 07 October 2025 04:13:29(UTC)
Aussie Susan
Just be careful that you don't melt any insulator on the wire.
You often need a lot of heat on the spade connectors to get them hot enough to melt the solder (and you need to do that to avoid a 'cold joint' - no pun intended) and that head can flow into places where you don't want it.
Susan
Offline mvd71
#7 Posted : 07 October 2025 09:01:44(UTC)
Not required on the crimped joint if it has been crimped properly. Soldering the connector to the track shouldn’t be required in as a proper spade connector should be tight fitting, however if it is loose fitting then a little solder may help. But caution the level of heat you put in, plastic track is not forgiving.
Offline Alex H
#8 Posted : 07 October 2025 09:17:16(UTC)
Alex H
Thanks everyone for your thoughts. It seems users are divided. I might try and see how difficult it is, but agree if the cable is crimped properly then it shouldn't come loose.
Offline dickinsonj
#9 Posted : 07 October 2025 13:16:51(UTC)
Just to be clear, I don't recommend soldering the connector to the track, just to the wire. Soldering the connector to the track would be a very bad idea in my opinion.
Offline Alex H
#10 Posted : 07 October 2025 13:33:24(UTC)
Alex H
Hi, No I wasn't intending to solder to the track. I was going to crimp the wire on the spade connector, then add a touch of solder and then push the spade connector onto the track .
I have done some tests and am happy that I wont need to solder and that the crimper I have is doing a good job!
Thanks again to all who took the time to comment - much appreciated
Alex
thanks 1 user liked this useful post by Alex H
This page was generated in 0.349 seconds.
