Offline Eddie7979
#1 Posted : 30 September 2025 01:57:33(UTC)
Eddie7979
Hope everyone is going well.
I am doing my first digital conversion, the first locomotive I’m tackling is the Marklin 3310 steam locomotive.
Luckily, I have some other locomotives that were converted by a specialist so I have something to compare to.
My question relates the installation of the 5 pole motor and those big teal coloured interference suppression chokes that comes with it.
Every conversion I see has them soldered directly to the motor shield. This makes it tight when I place the body back on so wanted to ask whether anyone has tried to install the ‘chokes’ onto the decoder a the wire soldered onto the shield?
Since there is so much room in the tender, it would make things so much easier.
Hopefully I’m making sense - be great to know your thoughts.
Eddie
Eddie
Perth 🇦🇺
Marklin | Roco | Piko
CS3+ & iTrain
Offline DasBert33
#2 Posted : 30 September 2025 08:18:19(UTC)
DasBert33
Sure yes, for steamers with space in the tender but not near the motor that is perfectly ok. I have done multiple conversions like that. The inductors/chokes just need to be in series between motor and decoder, but where exactly is of less importance.
Also do not forget to remove the capacitors between a motor shield contact and the loco body, if any. Only the single cap between the 2 motor contacts can stay.
Bert
Offline Eddie7979
#3 Posted : 30 September 2025 09:21:58(UTC)
Eddie7979
Bert
Hi Bert,
Thank you so much for the feedback and providing your experience. This will make things so much easier, including servicing in the future as well!
I was sure that this was possible but just in case, always good to collaborate and ask the question - just in case.
I have the conversion kit from Marklin, the motor shield has one cap which is staying.
Much appreciated,
Eddie
Eddie
Perth 🇦🇺
CS3+ & iTrain
This page was generated in 0.295 seconds.
