Offline FransCronje
#1 Posted : 29 September 2025 10:22:23(UTC)
FransCronje
Morning everyone
I am thinking of getting the 36712 set, will it be possible to extend the set with 3 cars to make it a 7 piece unit?
Frans
#2 Posted : 29 September 2025 11:18:25(UTC)
Hi Frans
I don't have this set so take my advice with a grain of salt.
Researching on the topic I found the exact same question as yours asked in the German Stummiforum
https://www.stummiforum.de/t1628...M-rklin-Erg-nzungen.html
If I understand correctly, the ICE starterset differs from the regular ICEs with a different and simplified electrical connection.
The item 44322 in the Start-up line is an extension of item 29320 (2012-2014) while item 39712 (2014-2025) is a four unit set (previous unit 29320 was a 3 unit set).
Your question: is a 7 car train possible?
The answer is about traction power and since there are no sliders in middle cars, the answer is probably yes with "gentle" slopes (3% or less) and clean track
Just my two cents worth
Offline FransCronje
#3 Posted : 29 September 2025 13:01:08(UTC)
FransCronje
Hi Jean
My main concern is also traction, hence my question, I actually think that as it is a start up set, that’s the reason Marklin is not offering additional wagons, but I have the wagons.
I am thinking of installing the front drive bogie, then it have 4 axles powered.
#4 Posted : 29 September 2025 14:23:49(UTC)
AFAIK the 36712 has already a 4 axle drive with 2 traction tire on the rear bogie so with clean wheels and rails and plastic cars it will be OK.
This is a compromise by Märklin to provide good current pick-up and reliable occupation detection already by the front bogie.
Just, periodically clean the wheels and tires with a cotton bud and Isopropyl alcohol
Here is the exploded view of the unit you consider purchasing (with two traction bogies and a central motor
To increase the traction power (not sure you need it) you may order a rear drive bogie E108 048 (30€) but flagged in yellow (not immediately available so better call Märklin shop)
https://www.maerklinshop.de/search?sSearch=E108+048+
Offline FransCronje
#5 Posted : 29 September 2025 14:32:43(UTC)
FransCronje
The Marklin website refers to 2 axes powered, that’s part of the confusion, the drawing stipulates the details may vary.
#6 Posted : 29 September 2025 14:36:37(UTC)
It's an affordable start set which has no red tail/marker nor interior lighting. Only reversing headlights, always on in cab control car???
The feature description doesn't say if the train can be expanded with additional coaches. There have been a couple of different coupler designs so only a certain type of add on car will connect to it.
Offline FransCronje
#7 Posted : 29 September 2025 16:25:03(UTC)
FransCronje
I will be upgrading to msd3 decoder, and all the coaches do have the correct coupling, I basically only want the drive unit.
thanks 1 user liked this useful post by FransCronje
#8 Posted : 29 September 2025 17:02:43(UTC)
You are sadly correct. Märklin has removed some part to lower their cost.
Must see if in reality the motor is fitted
One wild gamble is your idea: how about adding a supplemental rear bogie to the front with the following issues to adress
- negociate with M to obtain a supplemental rear bogie
- get a new transmission shaft or make one I think both transmission shafts are identical. Märklin describes them as Kardanwelle E216 777 €7.50 for two shafts and in stock
- adatpt a slider into the extra rear bogie. Chances are the same bogie frame is used on both the front and rear ones so only a matter of moving or adapting a small contact plate to collect power from the slider
- make sure the existing motor is fitted with a transmission joint on both sides
An interesting project
Offline frans
#9 Posted : 30 September 2025 20:43:13(UTC)
frans
Hi Jean
Will keep the post updated as the project continues
fc
This page was generated in 0.369 seconds.
