Offline ParisTsirchoglou
#1 Posted : 23 September 2025 11:50:09(UTC)
ParisTsirchoglou
Hello everybody, please I need your help.
I have on my display cabinet for 9 years now the beautiful Marklin 37565-1 SBB class Ce 6/8 II "Crocodile", which I bought new from my dealer. Since then, I have never seriously tried to “open” (raise) the pantographs, since (to be honest) I was afraid that I would damage them trying.
Can you please tell me how to open (extract) them? Thank you in advance.
Paris
Era I and Era II German and Swiss Steamers and E-Loks. Proud owner of a Challenger (-;
#2 Posted : 23 September 2025 14:31:43(UTC)
Just don't force them! If you can not pull it a bit to the side to release the locking tab, use a pair of tweezers to adjust the tab angle so they release.
thanks 3 users liked this useful post by marklinist5999
#3 Posted : 24 September 2025 12:11:40(UTC)
ParisTsirchoglou
Thank you!!! I will do just that ...
thanks 1 user liked this useful post by ParisTsirchoglou
#4 Posted : 25 September 2025 02:27:57(UTC)
There are two little pins underneath the ends of the pantograph blade. Those pins fit into slots in the base of the pantograph. You must gently slide the pantograph to one side and then slide it back so that the pin does not go back into the slot/tab. As you move the pantograph back in the other direction, the second pin should pop out of the other slot and you will then be able to raise it. Some models have a solid base and others may have a split part which forms either side of the slot.
I have used an image of a Sommerfeldt pantograph to show the location of the pin and the slot.
#5 Posted : 25 September 2025 11:22:10(UTC)
ParisTsirchoglou
Mike THANK YOU very much. I already tried this, but maybe I was not brave enough to slide the pantograph far enough to one side. I will do it again and I will try to ease the slot with a pair of tweezers (to avoid putting all the stress to the pantograph's moving parts).
Best Regards.
Paris
#6 Posted : 26 September 2025 04:06:46(UTC)
As you slide the wiper (top) pin to one side, once it has slid past the point where it is free from the slot, lift it slightly so that when you slide the wiper back the other way, it will not go back into the slot. This way, once the other side has cleared the slot, you will be able to raise the pantograph. Use care so as not to damage the retaining clips or slot.
Offline bgemski
#7 Posted : 05 November 2025 15:26:42(UTC)
bgemski
They can be a little finicky to get open. Patience and care are required.
thanks 2 users liked this useful post by bgemski
This page was generated in 0.345 seconds.
