Offline fje
#1 Posted : 21 September 2025 19:53:10(UTC)
fje
Hi, I got a new/old (second hand) CS2 60213 that gives me some troubles.
I am testing with it several Mfx locs in a couple of test tracks I built using M-tracks and C-tracks.
I should say that neither of both test tracks are pretty new (of course) and maybe not 100% clean, but when I use them with the same locs using an (also old) Intellibox I, I don't have any problem, except that the loc can stop due to a problem of current micro-cut due to dirty in the tracks or the "pukos", but nothing more.
CS2 60213 instead changes the loc direction or even switch on a loc function. It seems CS2 is much more sensible to a possible current micro-failure than the other (old) Intellibox.
I am afraid that when I would use it in one of (from time to time) built layouts it would give me many troubles because my tracks ar old and impossible to have them 100% clean.
So, is there any way to lower the CS2 sensitivity to those micro-cut of current in possible dirty tracks (or "pukos").
Thanks and kind regards.
Javier
P.S.: When I build a layout, I usually use a booster between the Control Station and the layout (mainly for protecting the Control Station), would it lower the sensibility micro-cut problems I find now?
#2 Posted : 21 September 2025 20:01:31(UTC)
Is it really a CS2 issue, i.e. does the CS2 show the change of direction and the activation of the function?
Maybe the sensitivity is with the decoders, depending on the protocol.
You can disable mfx in the CS2 and use MM and DCC as you do with the Intellibox to see if that makes a difference.
If the sensitivity is with the CS2 then a booster might help. A non-mfx booster will isolate the CS2 from the track and there should be no way of interference from dirt on the rails.
Offline fje
#3 Posted : 22 September 2025 08:11:33(UTC)
fje
Thanks. Yes, the change of direction and the activation of the function are seen in the CS2, so, it seems to be a problem of the CS2.
On the other hand, both decoders (37921 and 37886) seems to be Mfx-only decoders, but I will try your suggestion of test them using MM protocol in order to isolate the problem between the decoder/protocol and the CS2/protocol.
I will also try it putting my booster (It is a "Do it yourself" Märklin 6017-like)
But everything has to wait a couple of weeks, as I am not at home just now, so, no access to them.
Thanks again and best regards.
Javier
Edited by user 22 September 2025 22:51:09(UTC)  | Reason: Not specified
#4 Posted : 22 September 2025 12:44:01(UTC)
I will also try it putting my booster (It is a "Do it yourself" Märklin 60174-like)
Where did you get information to make one of these? I would appreciate a link if possible.
TIA
Offline fje
#5 Posted : 22 September 2025 13:16:03(UTC)
fje
TIA
I got it from another Spanish colleague, in fact I got it already built, but I feel I have all the documentation, the components, the electronic circuit and components and even the electronic board design, should you be interested in, I can contact my colleague (if still available) and ask for sending you information or selling you a board (is still available).
#6 Posted : 22 September 2025 18:50:51(UTC)
TIA
I would appreciate that if it is still available.
Thank you
Offline fje
#7 Posted : 22 September 2025 21:50:11(UTC)
fje
I will try to contact him and will let you know if any news.
In the meantime let me correct my previous post. It is not a 60174-like booster, but a 6017-like booster. It admits common-mass and DCC and Motorola protocols, don't sure about Mfx yet, in a couple of weeks I could confirm.
Rgds
thanks 1 user liked this useful post by fje
Offline fje
#8 Posted : 24 September 2025 16:37:01(UTC)
fje
TIA
Thank you
I am very sorry, but, after trying in different ways, I am not able to find a way to contact the one that developped it... it was 12 years ago. He used to have a blog and a user in Facebook, but both seems to be inactive since years, and people that shared the hobby with him don't have news of he since years too.
#9 Posted : 24 September 2025 21:11:11(UTC)
Hi Javier
I had one 60213 and one 60214 and both went back to Märklin where the motherboard was replaced by a 60215 one and this was a real fix.
My experience is that the 60213 had serious design flaws around (1) the absence of galvanic separation and (2) the feed-back bus for S88 (6088 / 60880)
Back to your problem
The possible causes are (in decreasing probability):
- defective can bus receiving erratic order from another ghost equipemnt. You said you developped your own equipment (Booster) it must be connected either to the flat cable under the 60213 or to the CAN output
- noisy power supply (having high frequency superposed to the normal AC or DC). Are you using a transformer or a regulated DC power supply (e.g.60041 or 60101).
- defective touchscreen (I experienced this on my CS1 (60212) caused by a mechanical problem - the CS1 casing was touching the touch screen)
Have you tried the 60213 alone with a loco? Do you still have the same issues?
FYI today one of my 60215 work but with a dead programing track output and the second one fails to boot-up (the initial start image is displayed forever) and now I use a CS3 (60226) since 4 years and its fine.
Offline fje
#10 Posted : 25 September 2025 13:42:34(UTC)
fje
Hi, Jean, thanks for your answer and suggestions. Let me answer you point by point.
You are right in the difference and problems of 60213 vs 60215, but I feel that the cost of sending my 60213 to Marklin and changing the mother board would cost me much more than a new (second hand) 60215 one. So, I am afraid I have to stay with the 60213 I got.
The test I did (and the problems I got) was connecting DIRECTLY the 60213 to the test track, no intermediate booster between them, so this answer your first possible cause and the question about the 60213 alone with the loc. Yes, this was my test. My next one will be (in a couple of weeks that we will be back at home) a test with the "6017 like" booster as intermediate.
Power supply I use is the one that comes with the 60213, I don't remember the Märklin id at this moment, and I am not at home, but it is the one for 60213, might be the 60065.
And, it is not a touchscreen problem, it comes without touching the screen.
#11 Posted : 25 September 2025 22:26:01(UTC)
Yes and besides, Märklin does not repair them anymore since 2019 or so. M offers a rebate on CS3 if they keep the CS2 for destruction
#12 Posted : 26 September 2025 05:23:40(UTC)
I think I remember someone once had a problem, where a tiny seed or similar got in between the touchscreen and the casing,
thus applying a little pressure on the screen, which then caused a problem... Blink
#13 Posted : 27 September 2025 18:52:09(UTC)
TIA
Thank you
Ah, if it is a 6017 equivalent then don't worry, I have information on these.
Thanks anyway, for your efforts.
Offline fje
#14 Posted : 09 October 2025 11:46:36(UTC)
fje
I was finally able to do some test and put some update today:
1.- Power supply is 60052.
2.- Efect of stopping and start/stop a particular function occurs both with direct connection to the main track or thru the "6017 like" booster
3.- There is a great dependency of the track clean/dirty ans of having had the loc running several times over the tracks after having "cleaning" the tracks.
4.- There is a highs dependency of the loc speed, the lower it is, the higher probability of the problem, the higher the speed, lower problems arise.
5.- Even more, not only the actual speed, some time the "desired" higher speed, the lowest probability of problem.
That's all my tests of today. I had a couple of days with the possibility of doing them and I did....
Best regards.
Javier
P.D.: I found there is a new update for the CS2, I will do it and, if I have time in this week, I will do further test, even I am not very optimistic that it will solve this "too sensible to dirty tracks" problem.
Guest (10)
This page was generated in 0.494 seconds.
