Offline Gaston Sallaber
#1 Posted : 15 September 2025 17:31:25(UTC)
Gaston Sallaber
Argentina
Hello. Thanks for accepting me on your forum.
I have two 84kW and an MS2, plus a 52V transformer. I don't know how to wire them. I want to wire 8 of them, one to work with the model lights and the other to power isolated tracks. If anyone can help me, I'd appreciate
thanks 1 user liked this useful post by Gaston Sallaber
#2 Posted : 15 September 2025 18:45:44(UTC)
Gaston, welcome! Do you have two M84? The MS2 uses a round multi pin cable and connector to a track box. The box has female pin jacks for two MS-2's. The transformer, or wallwart is a 120 volt or 240 volt ac to 36 watts dc voltage at 18 volts.
The MS2 recognized MFX devices and Locomotives automatically, or Marklin Motorola format or other brand DCC ones by manually entering them. M-83 and M-84 decoders are MFX. K-83 or 84 accessory decoders were 16 volt ac devices. So, you would isolate them from a C tracks with the red pointy plastic push in isolators between tracks. Two at each end as explained in the manuals. You then wire another 16 volt output transformer to the isolated track block or blocks, using the accessory terminals on that transformer, which can also be used for lighting. Remember to keep the B and O terminals wired to all tracks the same to prevent short circuits.
I hope I helped you.
#3 Posted : 15 September 2025 19:00:40(UTC)
Gaston Sallaber
Argentina
la idea es mantener en digital el circuito del deco k84 no se como conectarlo desde la ms2 para las vias. y el otro k84 sera independiente para las luces pero tampoco se donde van los cables.
perdon pero recien empiezo en digital
Gracias igual por la respuesta
marklin # sk 846/4 h ? (H0-scale)
by chris1976 09/07/2007 10:35:29(UTC)
This page was generated in 0.317 seconds.
