Offline Thewolf
#1 Posted : 09 September 2025 00:04:16(UTC)
Thewolf
Hi gang Cool
I have signals 74371 and 74391. I am working with the decoder M84 and the CS3 60226. I have no configuration problems with the 60226, the M84, and the 74391.
The 74380 is really giving me a hard time in the configuration.
The 74380 being the advanced signal of a 74391, is there something special to do in the cs3 to couple the 2 signals?
Because in the manual of the M84, I have seen that the 74380 unit will connect to the M84 pin related to the appropriate 74391 connection, I am a bit lost, especially that I have things going on that I don't understand in the cs3 with the addresses of the articles and the addresses of the decoders.
Thank you for your advices
Thewolf
Online marklinist5999
#2 Posted : 09 September 2025 14:07:59(UTC)
I would also like to know the solution. I only currently have a 76XXX signal with integral decoder.
Offline rhfil
#3 Posted : 09 September 2025 14:27:59(UTC)
rhfil
Can't help you with the signals but perhaps with the addresses. If the items are mfx the CS3 will assign an address that is unique to the article. Most mfx items allow you to choose either manually setting the address or allowing the CS3 to do it. On switches for example you can either set the address manually or not. I prefer to manually set them. I don't know whether the article addresses and the loco addresses can conflict. It is possible to assign the same address to two articles. As an example you can have two switches on a siding operate in parallel by assigning them the same address.
#4 Posted : 09 September 2025 15:10:09(UTC)
Perhaps Modeltrainfunguy on Youtube explains it. I have seen his videos. I think he has one on installing signals on the CS3 in tandem, mfx, as well as dcc using the dip switches on them and the M84.
Offline rhfil
#5 Posted : 09 September 2025 17:32:17(UTC)
rhfil
Model train fun videos are the best. He really goes through great lengths to make his presentations understandable. I find myself going to them repeated times when I have forgotten the instructions. One of the few things I subscribe to.
Offline Thewolf
#6 Posted : 09 September 2025 21:29:55(UTC)
Thewolf
GuysCool
?si=cIzIOLdzl47ejOdj
In this video, the main thing is missing: the configuration of the 2 signals 74491 and 74480 in the cs3. If someone could inform us how to do it, that would be great.
Thank you to all
Thewolf
Offline rhfil
#7 Posted : 10 September 2025 02:28:31(UTC)
rhfil
Do they have decoders in them? Otherwise they can not communicate directly with the CS3. The M84 slot that they are wired to is how the CS3 communicates with them. Similar to the uncoupler track. It has a solenoid which is activated by the M84. It is possible to connect the activation with the icon on the CS3 screen so that touching the icon activates the uncoupler track.
#8 Posted : 10 September 2025 14:18:19(UTC)
That makes sense, so the same way I use an old 7039 semaphore signal with the M-83.
Offline Grand trunk
#9 Posted : 10 September 2025 15:40:00(UTC)
Grand trunk
If both of your signal are on position 1, they should work together as one. Look at changing the signal to red when the train passes.
thanks 1 user liked this useful post by Grand trunk
Offline Thewolf
#10 Posted : 11 September 2025 15:27:49(UTC)
Thewolf
GuysCool
For those who want to know how to do it, and I think there are quite a few, here is the answer I received to my question from a member of this forum who, in my opinion, really knows what CS3 is all about, JohnjeanB :
1 Normal use
As the m84 is designed to control 4 main signals and 4 advance signals, only the main signal will be displayed even if, on the network, the main and advance signals are controlled by a single command. The advance signal and main signal are connected to the same location. The symbol on the CS3 will be that of the main signal. The advance signal will not have a symbol on the CS3 screen.
2 Special use
If you want to have advanced signal symbols in addition to the main signals, then you must use a single signal per location on the m84 Advanced or Main, and you can choose the appropriate symbol and control each signal individually.
3 Tip with virtual signal
Proceed as in normal use, but add two advanced signal locations on the CS3 and create the advanced signal symbols.
This is a virtual location with an address to be chosen from those available.
Create an event to copy the status of the real main signal to the virtual advanced signal.
This way, the main signal and advanced signal symbols can appear on the synoptic.
Have a nice day
Thewolf
thanks 3 users liked this useful post by Thewolf
This page was generated in 0.344 seconds.
