Offline Rocca
#1 Posted : 06 September 2025 18:31:47(UTC)
Rocca
Dear Märklin Friends,
I do hope that this post isn't out of topic, but I do need really some help. Many years ago I've purchased in the years the Hielscher's Wuppertal Schwebebahn Modell. I do enjoy it a lot in my Märklin H0 Layout. Unfortunately since many years Hielscher' Shop and Fabric is totally closed and you can't find anymore spare parts. I do need new rubber bands to make the mechanism working right again. You have here some pictures. I hop that somebody who still has this marvellous model can help me.
Thank you so so so much
Stefano
https://www.marklin-user...Rocca/550_1000030567.jpg
https://www.marklin-user...Rocca/550_1000030566.jpg
thanks 1 user liked this useful post by Rocca
Offline DasBert33
#2 Posted : 06 September 2025 19:57:24(UTC)
DasBert33
It looks like something that might be available on amazon or similar. A quick search on 'rubber band' yields some candidates. What is the specs of the bands you need (diameter, thickness, ...) and how much tolerance is there on these specs?
thanks 2 users liked this useful post by DasBert33
#3 Posted : 06 September 2025 20:01:37(UTC)
In a 2025 post a Stummiforum member mentioned that the "Wuppertal Achse" H0 scale modeling association deals with Hielscher "Schwebebahn" models, among other things. Their contact page:
https://www.wuppertal-achse.de/Kontakt/
Offline Unholz
#4 Posted : 07 September 2025 11:45:42(UTC)
Unholz
Slightly off topic (sorry), but just on the evening of the day before yesterday the historic "Kaiserwagen" of the actual Wuppertaler Schwebebahn has successfully completed its first test runs after many years of reconstruction and renovation. https://www1.wdr.de/nach...n-faehrt-wieder-104.html
Offline Rocca
#5 Posted : 07 September 2025 14:48:44(UTC)
Rocca
Happy Sunday, dear DasBert,
The cross-section is circular, and the length of the broken belt is 9.49 cm, while the diameter is 2.99 cm. The cross-section is 0.5 mm.
Thank you very much!
Stefano
thanks 2 users liked this useful post by Rocca
Offline rhfil
#6 Posted : 07 September 2025 15:29:42(UTC)
rhfil
That is not a rubber band but an O-ring. Rubber bands are flat and stretch. O-rings are round and have little stretch. In America a good hardware store will have an assortment of them. Not sure about outside.
thanks 4 users liked this useful post by rhfil
Offline marklin81
#7 Posted : 07 September 2025 20:29:35(UTC)
marklin81
As mentioned, it seems to be an o-ring (not a rubber band). The dimensions you provided indicate a 0.5x30mm size.
Searching on eBay for those dimensions kept producing o-rings/gaskets for watches -- that may provide the right size for your needs. I'd recommend including "watch o-ring gasket 0.5x30 mm" when searching.
Good luck!
Pat
thanks 3 users liked this useful post by marklin81
Offline DasBert33
#8 Posted : 07 September 2025 20:46:36(UTC)
DasBert33
o-rings with the specs you mention are available on amazon. i would try those.
thanks 4 users liked this useful post by DasBert33
Offline Rocca
#9 Posted : 08 September 2025 18:03:05(UTC)
Rocca
Good luck!
Pat
hi Pat,
I'm tchecking my luck with these ones https://www.amazon.it/dp/B0FH2GVF2R?ref=ppx_yo2ov_dt_b_fed_asin_title for now. I'l let you know when they will be delivered at my home!
thanks 3 users liked this useful post by Rocca
Offline HO Collector
#10 Posted : 11 September 2025 23:04:36(UTC)
HO Collector
Exactly my thoughts.
Go to a large car spare parts shop and take your 'O Ring' as a sample
thanks 2 users liked this useful post by HO Collector
Guest (7)
This page was generated in 0.367 seconds.
