Offline Dirtboy
#1 Posted : 24 August 2025 18:25:12(UTC)
Dirtboy
I have the new Märklin 051 lok (37814) that comes from factory with a buffer capacitor. I'd like to swap out the factory decoder for an ESU LokSound5 decoder. I just don't like the way Märklin does their steam sounds. Does anyone know if I will be able to program the CV's needed for the buffer capacitor into the ESU decoder?
I compared the buffer capacitor CV's of the lok to the CV table of the stand-alone buffer capacitor 60974 and not all of the CV's are listed on the lok (at least from reading the lok on the CS3). Does anyone have any insight to this?
Here is the lok in question:
#2 Posted : 24 August 2025 18:45:08(UTC)
To use a buffer capacitor with the ESU decoder you will need to use an ESU buffer capacitor, not the Marklin one. The ESU capacitor does not have on-board CVs like the Marklin one, but one of the normal Aux outputs is used to control it. Refer to the ESU documentation for details.
Offline Dirtboy
#3 Posted : 24 August 2025 19:19:23(UTC)
Dirtboy
I have several loks with ESU decoders and ESU buffer capacitors so I'm familiar with them. I'm not familiar with the new Märklin buffer capacitors built-in to the loks from the factory. Is there a way to bypass them without de-soldering them from the Märklin decoder adapter board?
#4 Posted : 25 August 2025 18:36:54(UTC)
There is no buffer capacitor in the model.
I did just checked at Märklins homepage and there are no information about buffer capacitor!
How did you get this locomotive with the power cap?
Offline Dirtboy
#5 Posted : 25 August 2025 19:01:19(UTC)
Dirtboy
I guess Märklin forgot to add this detail on their website as well as in the instruction manual included with the lok. I can assure you, this lok definitely has not only one, but two buffer capacitors in it. Buffer 1 is for sound and motor and buffer 2 is for lights and AUX outputs. When I cut power to the track, the lok keeps running for a second or two and the sound continues.
Plus, you can see in the lok's setup menu on the CS3 that the capacitor is labeled as an "electronic flywheel":
I don't know why Märklin didn't announce that this lok has a buffer capacitor...
thanks 1 user liked this useful post by Dirtboy
Online bph
#6 Posted : 25 August 2025 22:20:56(UTC)
You are probably right, and the locomotive has a buffer capacitor. But if it has two?, they are probably linked. The menu probably only refers to configuration setting 1 and configuration setting 2, not separate capacitors.
One setting I notice is that AUX 4 is always on, and AUX 4 is configured to the Voltage buffer control setting.
So you need to check with ESU, regarding compatibility.
Offline Dirtboy
#7 Posted : 26 August 2025 00:10:12(UTC)
Dirtboy
You're correct about the lok only having one capacitor:
I thought it may have been the same setup as the 60974 add on capacitor from Märklin:
#8 Posted : 26 August 2025 05:45:44(UTC)
Be attention about PCB!
I don´t believe you can put ESU sound decoder there.
ESU does not have same output physical functions like Märklin do have.
Offline Dirtboy
#9 Posted : 03 September 2025 20:11:17(UTC)
Dirtboy
Well, I sent an email to Märklin Digital asking about this and the reply I got was- "Hello Derek, there is no way for us to know what would happen with a third-party decoder. We don't test for this since the locomotive is supplied with a working decoder."
I also had a lengthy discussion on the ESU German forum about this issue. As of right now, there is no way for an ESU decoder to control the Märklin buffer capacitor. However, I might be able to swap to an ESU decoder and just disable the Märklin buffer capacitor; then just use an ESU PowerPack capacitor. As much as I don't like the steam sounds Märklin produce, I don't think I am going to install an ESU decoder and PowerPack right now (might wait until the warranty runs out).LOL
I listened to some of the sound files available for the mSD3 decoders and wasn't impressed either.Glare
Guess I just have to live with sub-par steam lok sounds coming out of my BR051 for a while.
#10 Posted : 05 September 2025 18:54:54(UTC)
You cannot swap the buffer capacitor to ESU because you have still problem with the locomotives PCB.
ESU does not have same physical function outputs like Märklins.
If you decides to use ESU decoder anyway you have to remove PCB.
This page was generated in 0.379 seconds.
