Offline ciderglider
#1 Posted : 30 August 2025 16:49:19(UTC)
ciderglider
I am using Anyrail software to design a layout with some passing loops. It was all going well until I enabled the display of "inaccurate connections", which is where track pieces don't fit precisely. I've read that sometimes these alerts in Anyrail are in reality false positives, where the flexibility of the track allows the connection to work.
I hope this will be the case with my layout, but I find that passing loops with Marklin's Z track a bit of a minefield. The 0926 Track Plan book doesn't have examples of more complicated passing loops, e.g. using "trees" of points, or slips. So I can't be sure I haven't made a mistake in how I have arranged the track.
Any advice gratefully received!
#2 Posted : 30 August 2025 18:24:44(UTC)
I don't know anyrail but I use Wintrack which allows track bending at each junction (0.5° to a very few degree)
The reality is on long curved track there is a real flexibility even with C Track
On straight streches there is no escaping the geometry rule (if you miss 5 mm here then it will still be 5 mm even after 3 meters of track
I found that all track types are very easy to cut to the proper length, using a diamond disk
Here is a sample of track surgery I made on a C-Track triple switch
In fact doing this surgery allows you to create ANY track piece you need with "normal" extremities (the C-Track end in my case.
Offline Chas
#3 Posted : 31 August 2025 18:06:40(UTC)
Chas
I just lay it and jiggle 1/2mm here and there, as long as the electrical connections are good that sort of gap still works or even larger. Try centre line view that will tell you the degree of outness.
Offline ciderglider
#4 Posted : 31 August 2025 20:37:23(UTC)
ciderglider
I will try centre line view, thanks for the tip.
I have found that if I change the order of the track sections, but keeping the overall length of the track the same, the inaccurate connection goes away. So either I am doing something wrong (quite possible) or Anyrail doesn't evaluate the accuracy of a connection reliably. I am going to take this up with Anyrail.
Offline ciderglider
#5 Posted : 07 September 2025 13:28:48(UTC)
ciderglider
I contacted Anyrail, and they pointed out where I was going wrong. I hadn't been using the Autoconnect option all the time. So now I have a plan without any "inaccurate connections".
This brings me to my next question regarding passing loops. I believe the loop needs to be isolated, using insulated rail joiners, to prevent short circuits. Do both the 0 and +ve rails need to be isolated, or is it sufficient just to isolate the +ve rail?
#6 Posted : 07 September 2025 14:20:37(UTC)
It is recommended to isolate both rails. Suppose you only isolate one, and then do the same with the next block, but in reverse? You are risking a current jump from one block to the other, and a short.
This page was generated in 0.253 seconds.
