Offline Train train
#1 Posted : 23 August 2025 08:13:09(UTC)
Train train
Hello Marklin users,
I have been out of model railways for a while and having previously been a DCC 2 railer I am seriously looking at returning but using the Marklin system, but I want to know if it's actually worth it. Is there any advantage for me to use Marklin instead of just using the trix two rail instead, I have only a couple of DC locomotives and would probably convert to AC by fitting a 3 rail pickup shoe and a ESU lokpilot Multiprotocol decoder. I live in a country where you mostly have to import stuff on model railways so availability for both systems is about the same. Although in regards to Marklin brands Marklin is easier to source then trix. None of my DC track or
Dcc controller have survived.
thanks 1 user liked this useful post by Train train
Offline rhfil
#2 Posted : 23 August 2025 13:25:58(UTC)
rhfil
The advantage of three rail is you can have reversing loops without electronics. Also contact reporting is simpler. As far as I am concerned Marklin is the best. I have a CS3 and love it. It is very intuitive. What you think would be the simplest way to do something turns out to be the way that works.
#3 Posted : 23 August 2025 17:13:29(UTC)
Besides the real advantage of 3 rails, Märklin offers a digital solution that is really great. It is called MFX. Not to be confused with MFX-compatible and M4 you may find.
Märklin is best when used NOT mixed with other brands (Roco, Fleischmann, Piko, etc). This is a complete system that has been thoroughly tested.
Having mostly Märklin keeps you future-compatible (Märklin does not tell anyone what are their developments)
So, using non-Märklin decoders with a CS3 is a disaster
Here is my purely Märklin layout
#4 Posted : 23 August 2025 17:39:42(UTC)
Marklin is excellent but like most systems is expensive. it is worth spending as much as you can on the controller and power pack. Go for the CS3 and you will have all you need. Locos and coaches etc can be added in time and start with a cheaper loco which allows you to experiment as you build the layout.
Offline Train train
#5 Posted : 23 August 2025 19:48:21(UTC)
Train train
Could you elaborate on why mixing is a bad idea? I would like to know, even if they are MFX compatible decoders?
Offline Train train
#6 Posted : 23 August 2025 21:52:49(UTC)
Train train
Where I'm stuck is Marklin make a 2 rail digital system for Trix so is digital control wise are the unique advantages to 3 rail AC. Please forgive me if this sounds argumentive I'm just really stuck on deciding.
#7 Posted : 23 August 2025 23:33:30(UTC)
For me Marklin C track is excellent and gives good running with the extra centre rail. As said above you can have reversing loops without any problems. You can look at what is available from both systems from catalogues.
Offline rhfil
#8 Posted : 24 August 2025 02:34:26(UTC)
rhfil
To me the main advantage of three rails is it eliminates the need for complex electronics with complicated layouts that include a reversal and also allow for simpler contact tracks. My first foray into model railroading after retiring was with ho dcc and my first layout included a figure eight with a manual reversing switch. I later found an electronic version but neither worked perfectly. And then I attended a model railroad show where I observed a Marklin CS3 in operation. It met all my goals. Three rails allows reversing without any electronics and the least complicated method of train recognition using contact tracks.
Offline Train train
#9 Posted : 24 August 2025 08:45:08(UTC)
Train train
Thank you
Offline Drongo
#10 Posted : 29 August 2025 08:21:02(UTC)
Drongo
Yes C track is great, however, the Marklin turntable for C track is an absolute dog - under no circumstance get one. The TT in Jean's video is not the C track TT but another one from Fleischmann which has been modified for the 3 rail system.
Offline BenPerr
#11 Posted : 29 August 2025 17:35:51(UTC)
BenPerr
Can you expand on why the C-Track turntable is a dog & what are the fixes if any? I bought the 74862 and would like to know more before I assemble it on my layout.
#12 Posted : 29 August 2025 20:54:42(UTC)
There is Roco turntable that also can be use with Märklin tracks.
#13 Posted : 29 August 2025 21:05:19(UTC)
There is various to control model railway layout.
Märklin K or and C tracks can also be use with DCC systems and Märklin have nowadays DCC protocol in the new digital locomotives and not only mfx can be use.
It depends if you want have total control of the Märklin trains like to configure mfx protocol and in this case you have to use CS3.
Märklin tracks are expensive and it will be fine to use two rail with the CS3 and use mfx protocol too.
Trix do also have mfx protocol in the sound decoders.
I use two rail and found out that Peco code 75 are excellent to use with the Trix trains too.
This page was generated in 0.529 seconds.
