Offline Train train
#1 Posted : 23 August 2025 08:13:09(UTC)
Train train
Hello Marklin users,
I have been out of model railways for a while and having previously been a DCC 2 railer I am seriously looking at returning but using the Marklin system, but I want to know if it's actually worth it. Is there any advantage for me to use Marklin instead of just using the trix two rail instead, I have only a couple of DC locomotives and would probably convert to AC by fitting a 3 rail pickup shoe and a ESU lokpilot Multiprotocol decoder. I live in a country where you mostly have to import stuff on model railways so availability for both systems is about the same. Although in regards to Marklin brands Marklin is easier to source then trix. None of my DC track or
Dcc controller have survived.
thanks 1 user liked this useful post by Train train
Offline rhfil
#2 Posted : 23 August 2025 13:25:58(UTC)
rhfil
The advantage of three rail is you can have reversing loops without electronics. Also contact reporting is simpler. As far as I am concerned Marklin is the best. I have a CS3 and love it. It is very intuitive. What you think would be the simplest way to do something turns out to be the way that works.
#3 Posted : 23 August 2025 17:13:29(UTC)
Besides the real advantage of 3 rails, Märklin offers a digital solution that is really great. It is called MFX. Not to be confused with MFX-compatible and M4 you may find.
Märklin is best when used NOT mixed with other brands (Roco, Fleischmann, Piko, etc). This is a complete system that has been thoroughly tested.
Having mostly Märklin keeps you future-compatible (Märklin does not tell anyone what are their developments)
So, using non-Märklin decoders with a CS3 is a disaster
Here is my purely Märklin layout
#4 Posted : 23 August 2025 17:39:42(UTC)
Marklin is excellent but like most systems is expensive. it is worth spending as much as you can on the controller and power pack. Go for the CS3 and you will have all you need. Locos and coaches etc can be added in time and start with a cheaper loco which allows you to experiment as you build the layout.
Offline Train train
#5 Posted : 23 August 2025 19:48:21(UTC)
Train train
Could you elaborate on why mixing is a bad idea? I would like to know, even if they are MFX compatible decoders?
Offline Train train
#6 Posted : 23 August 2025 21:52:49(UTC)
Train train
Where I'm stuck is Marklin make a 2 rail digital system for Trix so is digital control wise are the unique advantages to 3 rail AC. Please forgive me if this sounds argumentive I'm just really stuck on deciding.
#7 Posted : 23 August 2025 23:33:30(UTC)
For me Marklin C track is excellent and gives good running with the extra centre rail. As said above you can have reversing loops without any problems. You can look at what is available from both systems from catalogues.
Offline rhfil
#8 Posted : 24 August 2025 02:34:26(UTC)
rhfil
To me the main advantage of three rails is it eliminates the need for complex electronics with complicated layouts that include a reversal and also allow for simpler contact tracks. My first foray into model railroading after retiring was with ho dcc and my first layout included a figure eight with a manual reversing switch. I later found an electronic version but neither worked perfectly. And then I attended a model railroad show where I observed a Marklin CS3 in operation. It met all my goals. Three rails allows reversing without any electronics and the least complicated method of train recognition using contact tracks.
Offline Train train
#9 Posted : 24 August 2025 08:45:08(UTC)
Train train
Thank you
Offline Drongo
#10 Posted : 29 August 2025 08:21:02(UTC)
Drongo
Yes C track is great, however, the Marklin turntable for C track is an absolute dog - under no circumstance get one. The TT in Jean's video is not the C track TT but another one from Fleischmann which has been modified for the 3 rail system.
Offline BenPerr
#11 Posted : 29 August 2025 17:35:51(UTC)
BenPerr
Can you expand on why the C-Track turntable is a dog & what are the fixes if any? I bought the 74862 and would like to know more before I assemble it on my layout.
#12 Posted : 29 August 2025 20:54:42(UTC)
There is Roco turntable that also can be use with Märklin tracks.
#13 Posted : 29 August 2025 21:05:19(UTC)
There is various to control model railway layout.
Märklin K or and C tracks can also be use with DCC systems and Märklin have nowadays DCC protocol in the new digital locomotives and not only mfx can be use.
It depends if you want have total control of the Märklin trains like to configure mfx protocol and in this case you have to use CS3.
Märklin tracks are expensive and it will be fine to use two rail with the CS3 and use mfx protocol too.
Trix do also have mfx protocol in the sound decoders.
I use two rail and found out that Peco code 75 are excellent to use with the Trix trains too.
Offline Copenhagen
#14 Posted : 30 August 2025 12:43:15(UTC)
Copenhagen
The problems with mixing with other brands: Usually engines/locomotives from the big brands like Roco, Piko and Esu run fine on three rail. I've had issues with smaller brands where tolerances and stuff can give problems.
When talking about rolling stock. Other brands than Marklin usually come with isolated axles so if one wants detection isolated wheels can be an issue. I don't use detection but other brands than Marklin usually have smaller wheel flanges which can cause problems with derailments. I usually adjust the wheel spacing a smidgen down on non Marklin cars. Like if it comes with a spacing of about 14.5 millimetres I shorten it to around 14 to 14.2 mm.
Sometimes you can get AC wheels for non Marklin cars which can also solve the problems.
Offline Train train
#15 Posted : 30 August 2025 13:37:13(UTC)
Train train
Im aware of the advantages of easier wiring and much easier to make reversing loops, although I don't think I will have one on my layout. How does setting up Marklin track compare ease wise to setting up DCC two rail C track with trix?
Offline ocram63_uk
#16 Posted : 30 August 2025 13:44:25(UTC)
ocram63_uk
I started with 2 rail many moons ago. Returning to Marklin at a later stage, mainly when DCC came along. I've mixed, after converting, 2 rail locos with Marklin locos and most DCC decoders. I've sold the 2 rail locos and am now in a 'limbo' deciding what to do with my trains but the idea is to stick to Marklin locos and nothing else in order to avoid the need to convert them to 3 rails which is cheaper and better. Coaches of different manufacturers might need tweaking especially with the wheels and the tolerance on C track. Trix locos can be quickly converted to 3 rails just by plugging in the correct 'slider' pickup shoe. I never bothered with reverse loops and all the other stuff as it is too 'nerdy' when you need to start with Marklin and they are inherently 'out of the box'. Enjoy
#17 Posted : 30 August 2025 17:07:41(UTC)
If you are starting again then I would stick to one manufacturer and not have a mix. In time when you are happy with Marklin controls etc then buying from others is fine.
My view is spend most on the controller and power pack with C track and build from there. Dont rush in but take time and you will get plenty of help here as you move forward.
Offline Train train
#18 Posted : 30 August 2025 19:19:35(UTC)
Train train
Thanks. Would it be okay to apply this Advice but just convert the one 00 2 rail locomotive I have and don't get anymore until I am familiar with Marklin controls?
Offline DasBert33
#19 Posted : 30 August 2025 21:46:31(UTC)
DasBert33
honestly i would stick with 2 rail if i were you, mainly because of slidernoise, 2R rails looking better and having more choice in rolling stock and track material.
Offline Drongo
#20 Posted : 31 August 2025 08:24:40(UTC)
Drongo
Firstly, there are tiny plastic clips which are inserted at each track exit. 2 types of pins, one for an occupied track and one for an unoccupied track. These pins can easily fall out, or the TT can jam on them. The precision of the TT being laid on your layout is extreme. The slightest misalignment and the TT will jam.
Secondly, getting to run on a CS3 is complex, or if your using another controller, like an ECoS then it's a nightmare.
Thirdly, if your layout is run by TrainController, then you've got Buckley's of getting it to work.
This is my experience.
Greg
#21 Posted : 31 August 2025 16:34:54(UTC)
I would purchase a new mfx loco. Marklin have a cheap steamer I think the number is 30000 which is all you need to get started and experiment.
Keep things simple and also buy the Marklin book on running their system. ignore turntables etc and keep this type of item for later.
As said spend most on the control sysytem which will last for years with locos and coaches being added later along with signals etc.
Doint too much at the one time when starting is not great so go slow and understand the system as you go along.
Offline Train train
#22 Posted : 31 August 2025 18:06:27(UTC)
Train train
Thanks, maybe I will try this and save the conversions for later down the line.
Offline Ross
#23 Posted : 02 September 2025 04:35:41(UTC)
Ross
Greg, this is a very negative quote, the 74862 has better mounting than the 74861 model. I have seen both models working well.
The fine tuning of the programming pins is an easy fix see my article I sent you. For others that are interested look at my web pages either under TranController or Tips pages.
This just isn't true but the information is spread over a number of documents which I have listed in my article you need to read them to get a better understanding how the turntable is setup.
This statement is absolutely wrong. READ my article.
Greg
This is a summary of my article
The document provides a detailed guide on setting up and configuring the Märklin 74861 and 74862 C-track turntables with the TrainController software and CS3+ central station and ECoS central unit.
Märklin 74861 and 74862 Turntable Setup Overview
This document provides a comprehensive guide for setting up and configuring the Märklin 74861 and 74862 C-track turntables with the TrainController software.
CS3 Setup Instructions for Turntables
The setup process for the Märklin turntables using the CS3+ central station is outlined.
• Read the manuals for the 74861 and 74862 turntables and the CS3.
• The CS3 configuration for the turntable is not detailed in the manuals, requiring additional research.
• The turntable must be discovered as an mfx item, keeping its default address of 225.
• Proper initialization involves manually positioning the turntable and ensuring all detection pins are correctly placed.
TrainController Setup Challenges
The integration of the turntable with TrainController presents unique challenges.
• Initial attempts to control the turntable using the 7686 compatible settings were inconsistent.
• The turntable has two control sections: Movement Control (Address 225-236) and Feature Control (Address 236-240).
• Successful control was achieved by using pushbuttons for movement and features, with proper address configurations.
Advanced Turntable Control Features
Additional control features enhance the functionality of the turntable.
• Implemented macros for track position control and sound management.
• Created flagman indicators to manage entry and exit of the turntable bridge.
• Developed a system to monitor locomotive positions for safe operation on the turntable.
Fine-Tuning and Testing Procedures
Fine-tuning the turntable setup ensures optimal performance.
• Detection pins can be adjusted for better accuracy.
• The electrical connection on the turntable spoke track must be modified for proper block monitoring.
• Testing involved ensuring that the turntable responds correctly to commands and that all features function as intended.
Macro Appendix and Control Suggestions
A detailed appendix provides macros for controlling the turntable.
• Macros for each track position and operational commands are included.
• Suggestions for upgrading TrainController files to integrate the turntable effectively are provided.
• Users are encouraged to experiment with the supplied TrainController file for optimal setup.
Ross
thanks 4 users liked this useful post by Ross
#24 Posted : 02 September 2025 12:25:06(UTC)
Ross that is excellent information. However we are helping poster Train Train to get started with the Marklin system and I doubt negative comments about the TT is helping.
However I think your post would be great on a topic about the TT and might be worth starting one if you wish as it would be helpful for those having or thinking of getting the TT
David
Guest (7)
This page was generated in 0.595 seconds.
