Offline roundsaturn31
#1 Posted : 12 August 2025 04:29:38(UTC)
roundsaturn31
I now have a used Marklin 1 gauge steam locomotive with dynamic smoke and an MTH F3 A+A set.
They are going to run on a small around the room display layout using a Marklin mobile station 2 for control.
Wondering what you guys would recommend using as the power source.
I know to get the dynamic smoke working correctly Marklin uses I believe around 20v dc on the rails as in their item #60195 power supply.
Wondering if that will fry the MTH ps3 boards on the other locomotive?
Also wondering how many amps are needed, probably will only be running one at a time.
Thanks for any help or suggestions,
Todd
Offline blid
#2 Posted : 12 August 2025 11:08:34(UTC)
blid
Six years ago I used a CS2 with the 19VDC 60101 100W power supply and measured the power consumption. My MTH F3 AA, upgraded to PS3, used 1 to 1,5 A with smoke when standing still. 3.3 A when pulling 5 passenger cars in 30 scale mph. Voltage 18 V.
You can still find manuals on the MTH site, https://www.mthtrains.com/products and type the item number where it says “Search by SKU…”.
#3 Posted : 12 August 2025 12:58:44(UTC)
It should be noted that the MS2 is limited to 1.9 A, even with a 5 A power supply.
18 V DC are standard for the MS2. It can also be used with 19 V DC, but I don't think it'll make much of a difference.
#4 Posted : 12 August 2025 17:32:39(UTC)
roundsaturn31
So then if I am understanding, based on what was said by you guys the MS2 is not really adequate to run the locomotives that I have.
Furthermore, I should only hook it (MS2) up to a 19v 1.9amp power supply to protect it.
If I did that to test the layout out, any locomotive that starts to draw more than 1.9 amps would "trip" the power supply but the locomotive and MS2 would be safe.
If however I hooked it up to a 5amp power supply, and any locomotive starts to draw more than 1.9 amps, the locomotive and the power supply would be safe but I would "fry" the MS2.
Is my thinking here correct?
If so I guess I am now in the market for a central station 3??
Thanks for the advice,
Todd
#5 Posted : 12 August 2025 23:00:44(UTC)
No, the MS2 and the loco should be safe. But you can't get more than 1.9 A out of the MS2 trackbox. So there isn't any advantage in using a power supply with more than 2 A IMHO.
You can try your luck, but with a loco that draws much current you may have no fun because the STOP light will be more on than off.
#6 Posted : 13 August 2025 01:09:10(UTC)
roundsaturn31
OK, thank you.
So what is the solution in your opinion?
A central station because the rating is higher?
Also, hard to understand that the MS2 is listed as ok to run 1 gauge, I don't see the point. I also don't understand how using it in conjunction with a central station would keep it "safe".
Online xxup
#7 Posted : 13 August 2025 04:57:28(UTC)
My FD runs her Gauge 1 stuff with an old marklin 6021, with some 6017 boosters and one of those black and white transformers (might be a 6003) for each booster and the 6021. That's how we run the three train Xmas layout.
#8 Posted : 13 August 2025 08:23:21(UTC)
Central Station, ESU ECoS, Intellibox, whatever you like.
If you need mfx and/or MM, that will limit the choice.
If all your locos support DCC, then there is a wide range to choose from.
MS2 is enough to run a single I gauge loco, at least most of them.
A double heading with sound and dynamic smoke plus a train with interior lights may well be over its limits.
With digital, you need a booster that provides the track power.
With the MS2 system, you have handheld device that provides the "user interface" and you have the trackbox with the "brain" and the "booster", limited to 1.9 A.
Boosters have overload protection and switch off before they get damaged.
#9 Posted : 13 August 2025 16:28:46(UTC)
roundsaturn31
Thank you for all the thoughts and info.
Todd
#10 Posted : 13 August 2025 20:59:40(UTC)
OK, thank you.
Well, this depends on if you are trying to use an H0 track box, or a G1 trackbox. They are different, and I imagine the G1 has higher current rating. Check your catalogue for details.
#11 Posted : 13 August 2025 21:14:55(UTC)
They are different: The trackbox for I gauge has larger spade connectors.
The power rating is the same, confirmed somewhere by Märklin US a long time ago.
#12 Posted : 14 August 2025 02:50:39(UTC)
roundsaturn31
Yes, it is the Marklin 1 gauge track box.
Offline ari1982
#13 Posted : 26 August 2025 09:27:57(UTC)
ari1982
Todd
you can get away with MS2 with 2 locomotives if your layout is small like a circle around the Christmas tree. the new high efficiency motors don't draw that much current even on the heavy Marklin / LGB loco's with dual motors. if you start to add lights , accessories etc then you need the Marklin 60195 switching power supply that can supply 5A and only works with CS3. CS3 is overkill if you want your trains to go around a circle... it is great when you want to make complex even-bases programs like a really railroad with many complex scenarios, accessories and trains. You could buy a cheap DCC controller and power supply but some of the Marklin MFX functions will not work with it. The newer locos are fully DCC complaint but older ones are just MFX with limited DCC compatibility.
I would give the cheaper MS2 options a try, if it didn't work you can step up
thanks 1 user liked this useful post by ari1982
This page was generated in 0.426 seconds.
