Offline philippe99
#1 Posted : 09 August 2025 17:55:09(UTC)
philippe99
Hello
I bought a used 3075.
Contrary to the ad, the machine was in poor condition (a missing bogie, etc.).. but I have parts to repair.
When I opened the machine, I saw that it had been digitized.
I wondered...
To switch it from digital to analog, isn't it enough to set all the switches to zero?
There are four switches: two are already set to zero, and the other two are set to 1 (the positions range from 0 to 2).
Of course, there is no documentation.
NB: I don't have any other photo besides this one... which I used for the dispute... as the machine is being shipped back to me (the seller refused to take it back).
Thx
Phil
thanks 1 user liked this useful post by philippe99
Offline cintrans
#2 Posted : 09 August 2025 19:56:55(UTC)
cintrans
Aruba
Phil
That lok is a #3021 (V200), not a #3075 (BR216)
It has what seems to be a Delta decoder
Yes, switching all the switches to 0 will make it drive in analog mode
Jean-Pierre
Offline philippe99
#3 Posted : 09 August 2025 21:28:32(UTC)
philippe99
Originally Posted by: cintrans Go to Quoted Post
Phil
Jean-Pierre
Yes, you're right is a V200. I always make a mistake with my BR216 I also own.
Tx. will lower all the switches to enable analog
Phi
#4 Posted : 09 August 2025 23:53:28(UTC)
Phil
Jean-Pierre
Phi
As the decoder has only four switches it is an early Delta decoder - not the earliest version which had solder jumpers to set the address, but the next generation that came out after Marklin decided not to use the automatic analogue mode sensing that they were in dispute with the patent holders.
Offline Benders
#5 Posted : 12 October 2025 06:38:33(UTC)
Benders
I have a similar problem with a 3066 loco. It has a Delta? decoder with 4 switches ( either 0 or 1 ). I only run analogue locos via traditional transformers and thus cannot set/change settings. The loco is extremely slow and I want to increase its speed - have tried toggling the switches to no avail. I am about to remove the decoder and replace with a reversing unit. Before I do this is there some solution other solution that I could use?
Benders
Offline mvd71
#6 Posted : 12 October 2025 06:59:44(UTC)
Benders
The slow running will not be a result of the delta decoder, if anything it should be better than an analogue reverser as it consumes less power. You problem most likely comes from a motor and gear train in need of servicing.
Offline Benders
#7 Posted : 12 October 2025 11:45:05(UTC)
Benders
Thanks for the reply.
The motor has been overhauled and the gears cleaned. The wheels turn freely when when pushed along a surface or the tracks.
I have the 3067 loco which is identical except is has a superbly functioning reversing unit, and moves at a fast clip.
I don't have much faith in decoders as I have similar slow speed rates with other decoder locos.
Offline marklin81
#8 Posted : 13 October 2025 03:10:53(UTC)
marklin81
The wheels on a locomotive should not turn freely when pushed. That may be an indication of the problem. It could be that the wheels are slipping on the axles.
thanks 1 user liked this useful post by marklin81
Offline mvd71
#9 Posted : 13 October 2025 21:20:59(UTC)
When you say overhauled what do you mean by that? I am guessing you mean it was taken apart, cleaned, lubed, and reassembled?
An overhaul would include replacing worn gears etc…. And the wear on the gears can require close inspection to see. Once the gears begin getting worn they will become inefficient and reduce the performance of the loco. My experience has been that a loco that is needing overhaul will usually be slow running, and often noticeably different in performance in each direction. How is yours performing in the other direction?
This page was generated in 0.341 seconds.
