Offline Drongo
#1 Posted : 08 August 2025 08:37:22(UTC)
Drongo
Hi Everyone, I've tried to search for this information on this forum and on YouTube without much success. On YouTube I've found a lot of information about car breaks squealing but this is not what I want.
Can someone please explain how to setup the CV's to get the locomotives, with this feature, to work.
Greg
#2 Posted : 08 August 2025 10:19:40(UTC)
Hi Greg
First the official Märklin video (alas in German) about the brake sound ("Bremsenquietchen") parameters on mSD3 decoders, using a CS3
Here is a technical paper on the same subject by Märklin
https://www.maerklin.de/fileadmi..._-_Bremsenquietschen.pdf
Among these:
- CV64 Bremsschwelle: the speed value to be reached before any sound brake can be heard when setting the speed to zero
- CV164 Bandbreite: The higher value, the earlier the sound will be triggered
- CV 163 Auslaufkorrectur To adjust the brake sound so that it stops when the loco stops
Additional adjustment value parameters
- CV 4 Bremsverzögerung (BV) Inertia simulation. The highter, the longer it takes to come to a stop
- CV 63 Lautstärke: general sound volume (impacts all sounds
The whole list of CVs by Märklin decoders is here
https://www.maerklin.de/fileadmi...mLD-mSD_CV-Liste_DCC.pdf
I hope this helps. Sorry for the German but often, translations are bizarre
Offline Drongo
#3 Posted : 08 August 2025 13:52:52(UTC)
Drongo
Thank you very much Jean for the information. Now all I need to do is run it through Google translate.BigGrin
Greg
Offline rhfil
#4 Posted : 09 August 2025 16:38:00(UTC)
rhfil
One factor which is not mentioned is the amount of deceleration needed to activate the squeal. The best bet is to experiment with the locomotive you want to use the feature. Run the loco the way you will normally and then adjust the braking delay to what seems natural and the squeal to match.
#5 Posted : 09 August 2025 17:44:55(UTC)
The Loco must be going fast enough also. The brake squeal threshold can be improved upon often by adjusting the brake threshold in the decoder setup menu macro.
#6 Posted : 09 August 2025 19:28:32(UTC)
No amount of deceleration is needed simply if the loco stops abruptly, no breaking sound can be hearD
The real condition is the loco speed must have reached a minimum speed defined in CV64 (Bremsquieschen Schwelle = braking sound niveau)
This page was generated in 0.255 seconds.
