Offline Drongo
#1 Posted : 07 August 2025 14:44:13(UTC)
Drongo
Hi everyone, I'm having a friendly discussion with my friend regarding Events vs Traincontroller.
He uses Events and I'm using TC. I've tried to use events however it's been a long time since I did computing programming in Fortran 4 and why write a program when you can buy a complete program and just insert the relevant information ? Has anyone had success using events ? I've watched some videos on the subject on YouTube, however it seems like a lot of trial and error getting the basic steps functioning correctly.
Greg
#2 Posted : 07 August 2025 16:32:40(UTC)
Events on a CS3 are easy to use. Marklin produce a book (sorry dont have mine to hand at present) which gives information required. You dont write programmes just insert the information into the event. Add a loco plus turnouts etc. You can adjust speeds easily and add signals. I expect most owning a CS3 will use events as it avoids other software and is easy to use.
Can be fun setting it up and mistakes can just be deleted.
Offline Pasquiles
#3 Posted : 07 August 2025 20:12:23(UTC)
Pasquiles
Luxembourg
I use events and macros on the CS3, they work fine for me. Märklin book or the YouTube channel https://youtube.com/@modeltrainfun?si=n6W9MDKayYVjGU_0
Will provide you with everything you need.
Once you have all setup is very rewarding.
thanks 1 user liked this useful post by Pasquiles
This page was generated in 0.324 seconds.
