Offline Eddie7979
#1 Posted : 31 July 2025 04:27:22(UTC)
Eddie7979
Hi everyone,
I found some Bemo coaches for sale on eBay, there are made for HOe scale layouts. It’s rare to find these kinds of products on the market in Australia, so would potentially be keep to buy them if it was possible to convert them to suit the Marklin HO rails.
My question, is it just a matter of swapping out the wheels from HOe to an AC HO or something more complicated? I’m guessing it’s not possible, considering the new products Bemo have seem to categorised by scale (instead of one product and the offer of swapping wheelers).
I have attached a picture of the set, unfortunately there isn’t any product codes.
I don’t own anything from Bemo, this is something I want to have in the future to suit the Swiss themed section of my layout.
Really keen to hear everyone’s thoughts.
Eddie
Perth 🇦🇺
Marklin | Roco | Piko
CS3+ & iTrain
thanks 1 user liked this useful post by Eddie7979
#2 Posted : 31 July 2025 13:32:25(UTC)
I think you'd have to find ho axles and see if they fit in the underside notch clips if applicable and or change the bogies.
#3 Posted : 31 July 2025 16:41:13(UTC)
Hello, a few notes and answers:
1- Those are German coaches, not Swiss. Just an FYI :)
2- Bemo do make some retrofit bogies for standard HO scale, but I doubt they do this for the HOe models. They probably screw right in, just won't look correct for this type of coach
3- As a fully-custom job, It would not be hard at all to unscrew those bogies and screw HO ones in if you can find the right look
4- Regauging the wheelsets likely won't work. I don't have one handy to check, but it is a safe bet they will spread out to 12mm HOm (by design as Bemo make the same coaches for HOm), but there probably is not enough axle shaft to go all the way to HO.
Hope this helps, they are lovely coaches- I used to have a set in HOm
-JP
Edited by user 31 July 2025 20:32:18(UTC)  | Reason: Not specified
Offline 1borna
#4 Posted : 07 August 2025 20:19:24(UTC)
1borna
Croatia
Narrow gauge wagons are lower and narrower than standard wagons, so it's hard to fit a wider base on them and they would look ridiculous next to an H0 locomotive.
thanks 1 user liked this useful post by 1borna
This page was generated in 0.255 seconds.
