Offline jonas_sthlm
#1 Posted : 30 July 2025 14:56:53(UTC)
jonas_sthlm
My opinion is that Märklin has mounted the plow blades the wrong way around.
Picture of the originally mounted plow pointing toward the track, sometimes touching the middle of K switch.
When I turn it around, it looks more like Märklin's own product pictures.
They are positioned slightly higher, but this results in a more streamlined alignment.
Edited by user 23 August 2025 14:52:07(UTC)  | Reason: Not specified
thanks 2 users liked this useful post by jonas_sthlm
#2 Posted : 30 July 2025 16:03:22(UTC)
They look the same to me.
Offline bph
#3 Posted : 30 July 2025 16:16:12(UTC)
Mounted by Märklin or perhaps your dealer?
Mine were not mounted, but part of the extra parts that are included in the plastic bags.
Offline jonas_sthlm
#4 Posted : 30 July 2025 16:41:03(UTC)
jonas_sthlm
I mean that the plow blade is mounted the wrong way on the bracket from China to be assembled from the bag.
As you can see on the back of the blade, there is a height difference depending on how it is mounted. You also get a different angle on the blade, so it doesn't point straight down.
thanks 3 users liked this useful post by jonas_sthlm
Offline bph
#5 Posted : 31 July 2025 00:17:37(UTC)
Ah, i see what you mean. And i think you are right. Cheked my locomotives and it was correct on the E 991, but wrong/swapped on the F 1200. Did the blade's come loose easily, when you swapped?
Offline jonas_sthlm
#6 Posted : 31 July 2025 06:33:15(UTC)
jonas_sthlm
Thank you for confirming the E 991, as I haven't installed them on it yet ThumpUp
I used a scalpel to pry apart the blade and the mounting bracket, but I removed the entire piece from the model first.
The front behaves like a bus with overhangs; it's hard not to get the plow blade stuck in the middle of the K switches.
thanks 5 users liked this useful post by jonas_sthlm
This page was generated in 0.279 seconds.
