Offline Luciano
#1 Posted : 23 July 2025 15:44:35(UTC)
Luciano
Brazil
WhatsApp Video 2025-07-23 at 22.33.44.mp4 (6,391kb) downloaded 32 time(s). WhatsApp Video 2025-07-23 at 22.19.24.mp4 (6,763kb) downloaded 11 time(s).
The loco starts to move and stop, all the sounds works properly.
Already check the conections and try 2 different controllers, both with the same problem. Other loco runs normally at the same circuit.
Video attached correctly now (first in English, second in Portuguese)
Edited by user 24 July 2025 03:37:25(UTC)  | Reason: Not specified
Offline rhfil
#2 Posted : 23 July 2025 16:19:55(UTC)
rhfil
Is it Marklin? Too little information to provide any help. Did you try using a 9V battery to operate the motor? And what controller do you have?
#3 Posted : 23 July 2025 18:33:35(UTC)
Welcome to the forum.
There is no video attached.
Märklin 39250 is the Swiss Elephant with mfx. 39250
Offline ocram63_uk
#4 Posted : 23 July 2025 22:44:29(UTC)
ocram63_uk
This is like going to your new doctor for the first time and saying 'I'm ill'
I don't want to be rude, really?
#5 Posted : 24 July 2025 18:31:45(UTC)
The user has a CS and what appears to be a black MS2. He states that sound and lights work, but that none of his locomotives will move more than perhaps a stutter.
Here is my recommendation. Set up a test track made up of 4 to 6 straight sections
Connect one or the other controller
Run through a test of all functions, including lights, sound and motor
It is possible that the motor of one locomotive might be blocked/gummed up, but the chances that this would happen to multiple locomotives at the same time are much lower.
I am not a CS expert. I have a few MS2 that I use.
Edited by user 25 July 2025 07:41:55(UTC)  | Reason: Not specified
#6 Posted : 24 July 2025 21:36:33(UTC)
Not sure but are you saying that it is only one loco that does not work but all the the work as they should. If this is the case then the track and contoller are OK. Check the slider on the loco to enure it is straight and makes proper contact.
Offline Luciano
#7 Posted : 27 July 2025 02:50:48(UTC)
Luciano
Brazil
I cleaned all the contacts and the problem continues. Here's a video to show better. WhatsApp Video 2025-07-26 at 21.45.27.mp4 (2,998kb) downloaded 18 time(s). WhatsApp Video 2025-07-26 at 21.45.27.mp4 (2,998kb) downloaded 10 time(s). WhatsApp Video 2025-07-26 at 21.45.39.mp4 (3,071kb) downloaded 13 time(s).
thanks 1 user liked this useful post by Luciano
#8 Posted : 27 July 2025 21:41:38(UTC)
Do you have it set up on a route or recording etc on your CS2 which my not be set properly. Unlikey though. Can you replace the decoder. AS asked above did you try with battery.
AS you have checked the slider and cleaned everything I can only think the fault is with the decoder or motor.
#9 Posted : 28 July 2025 08:07:57(UTC)
I'm not sure the battery test works with such a modern loco.
It is unlikely that the decoder is not pushed down all the way, but I'd inspect that. It is probably in the tender.
If the loco no longer runs, but lights and sound are still working, then maybe one collector of the motor lost contact. To test for this, I'd open the loco and gently give the flywheel at the motor a quarter of a turn. Then apply power again and look if it gets moving.
Never try to turn the loco wheels by force.
If it moves again, then maybe a longer run-in is all it takes. If the issue shows again and again, a new motor may be required. A dare-devil might open the motor to fix it.
#10 Posted : 28 July 2025 09:14:32(UTC)
I did have same similar problem but it was digital protocol that was problem.
So i decides to use mfx instead and the loco did start move.
Strange but could be ghost problem for short moment.
The loco did start work normal again with the DCC protocol.
This page was generated in 0.436 seconds.
