#1 Posted : 23 July 2025 11:12:09(UTC)
FD has a good collection of MAXI locos and rolling stock and is about to expand this with a new loco and two passenger wagons.
The plan is to do a modest Garden Railway, but we are concerned about the durability of the old Marklin 1 Track and the new Marklin 1 track. Does anyone here have a garden layout that is in the sun? Ideally, we would love to hear from someone in Australia (WA or Queensland or western NSW) or perhaps from another country with a humid sub-tropical to tropical climate.
One concern is the UV sensitivity of the plastic components and the other is the corrosion on the rails.
#2 Posted : 23 July 2025 13:19:43(UTC)
I understand that Peco G1 track is supposed to be UV resistant, but the other trick would be to use lots of ballast so it covers the sleepers.
#3 Posted : 23 July 2025 13:55:56(UTC)
Seems I recall my dad using LGB track in the late 90s for his pond railroad. He bought it where he bought the train. My nephew still uses it indoors.
#4 Posted : 24 July 2025 22:14:46(UTC)
No personal experience here, but you could consider buying and using the rugged LGB track for the outside (if you can tolerate the look), and keep the finer (less coarse) Märklin 1-scale track for carpet-bahning and for other occations.
Offline ari1982
#5 Posted : 26 August 2025 09:20:57(UTC)
ari1982
Marklin 1 track is not for outdoor use, it will rust. You need LGB or Piko rails, that are made of solid brass.
thanks 2 users liked this useful post by ari1982
Offline Diesel2000
#6 Posted : 03 September 2025 16:07:05(UTC)
Diesel2000
LGB track is what you are after. I will stand up better than anything else in any conditions. I live in NA and we have heat/humidity and direct sun in the summer, and below freezing snow in the winter. My track stays out all year. If you are running track power you will need to clean it from time to time and that will depend on the climate more than anything.
thanks 2 users liked this useful post by Diesel2000
#7 Posted : 03 September 2025 22:36:35(UTC)
Thanks guys. In a month or so, FD will set up her test layout, using the Marklin track, in our new shed that is still under construction. This will give us an idea of the LGB track that we need for the garden layout. But a quick look shows that it is really expensive track. So it might be a slow and progressive build. I think that she is going to show off her new acquisitions on the Farcebook version of this forum, when she does the test layout. Cool
#8 Posted : 09 September 2025 06:41:28(UTC)
I just ordered 24 x 300mm LGB straight track to go with the 12 curved track pieces that arrived today. There is plenty of well priced track in the USA, but the freight to Australia is stupidly expensive. So I will just have to keep watching down here. It was described as R1 - I hope that 12 tracks is enough to make a circle. I need to buy a LGB catalogue.
Offline blid
#9 Posted : 09 September 2025 12:51:54(UTC)
blid
While you wait for a catalogue you can check the site: https://www.lgb.com/.
If it is R1, item 11000, it is 30 degrees with 1290 mm diameter. Very tight in my opinion.
#10 Posted : 09 September 2025 22:00:19(UTC)
That should be okay for the little Maxi sets, but the new loco and wagons need a minimum radius of 1020mm or 2040mm diameter. That looks like R3.
It is a start.
The chart is here -> https://www.lgb.com/file...LGB_Gleissystem-Info.pdf
and here (in case the original link breaks).
https://www.marklin-users.net/up...LGB_Gleissystem-Info.pdf
They call it R1, but the actual dimensions are for the diameter - that is just nuts! It should be called D1, D2 etc..
Edited by user 10 September 2025 08:44:40(UTC)  | Reason: Not specified
#11 Posted : 09 September 2025 22:33:01(UTC)
That should be okay for the little Maxi sets, but the new one needs a minimum radius of 1020mm or 2040mm diameter.
It is a start.
Have you investigated the Peco track range? I don't know if Oz has an import agent.
Looks like there are two or three near Brisbane.
#12 Posted : 10 September 2025 08:40:23(UTC)
I had a look at the online shops for both Brisbane and Sydney. Only one store had any PECO G track - it was a turnout - very expensive. The other stores focus on H0/00 and N with some O gauge.
FD has heaps of Marklin 1 gauge track that she can use inside the new shed until we build up enough LGB stuff. I have just found 24 300mm LGB straights at a reasonable price, which will make a modest garden start.
This page was generated in 0.420 seconds.
