Offline michelvr
#1 Posted : 25 May 2025 23:29:05(UTC)
michelvr
I’m quite sure I will not be using C track but………..
Does anyone know what the capacity is for using the 74462 digital decoder C track on a larger layout?
I realize that there will be a power drain on the power supply but what is a reasonable amount before you use the K83’s?
#2 Posted : 25 May 2025 23:43:30(UTC)
The decoder is for turnouts Using my CS3 I dont see how there is a limit to the number on the layout. They change one at a time so dont see how there is a drain on the power supply.
I maybe dont understand the question.
Offline michelvr
#3 Posted : 26 May 2025 00:08:24(UTC)
michelvr
Just wondering can you use sixty without an issue?
Offline rbw993
#4 Posted : 26 May 2025 02:00:06(UTC)
rbw993
Yes, but more expensive!
#5 Posted : 26 May 2025 08:41:34(UTC)
The power consumption of a single inactive decoder should be 0.02 A or less.
The CS3 has 3 or 5 A output.
With 100 decoders you will probably be somewhere between 1 A and 2 A and there is still power left.
And if you have a track plan with 100 turnouts, you should prepare the layout for booster sections anyway.
Offline michelvr
#6 Posted : 26 May 2025 15:43:43(UTC)
michelvr
Thanks David & HO,
I have decided to renew my layout, possibly using K track and this decoder. The main reason being is by eliminating the wires under the layout.
#7 Posted : 26 May 2025 20:24:04(UTC)
Thanks David & HO,
I am not sure as I dont have K track but the decoder and motor are made to clip in to C track. Somebody with K track could maybe help and confirm no wiring is needed.
Offline rbw993
#8 Posted : 27 May 2025 16:06:00(UTC)
rbw993
Dave, you are right, these decoders aren't designed for K track. They plug directly into the C-track switch motors. To hook the to K track the plug connectors for power and motor will have to be clipped off. I think it is easier to use the K/M83 solution.
Roger
Offline michelvr
#9 Posted : 27 May 2025 22:03:17(UTC)
michelvr
Roger
I fully understand thank you for the help!
thanks 2 users liked this useful post by michelvr
#10 Posted : 28 May 2025 14:53:34(UTC)
Doesn't K track accept most any type/brand of solenoid actuator? Then you can use either Marklin M-84, or Viessman decoders.
#11 Posted : 28 May 2025 20:07:28(UTC)
Where would you put them. I suppose you could wire them under the baseboard but 70 of them would not be great in my view.
Offline rbw993
#12 Posted : 29 May 2025 14:01:44(UTC)
rbw993
18 M83 type decoders, 60382 is the current model, would be needed for 70 motors. They each control 4 switch motors. That comes out to around $1260. If you bought the individual decoders @ $44 it would cost $3080! Prices are approximate retail. You could probably get a bulk price break.
Viessmann makes an older basic style M83 which is quite a bit cheaper.
Roger
#13 Posted : 29 May 2025 14:53:20(UTC)
Lots of wiring too. Even if you mount the decoders under the layout centrally as possible plugged to each other.
This page was generated in 0.469 seconds.
