Offline bgemski
#1 Posted : 16 May 2025 15:46:19(UTC)
bgemski
Good morning, everyone. I have a question I'm hoping someone can give some insight or help with. I just recently purchased the Viessmann 5100 crossing gate. I also have a Marklin m84 decoder. I wish to install the crossing into my layout and, hopefully, use the m84 to integrate into my digital system. Major question, is this combination possible or not? Is there anything I need to be aware of? Both items are new and have not been used. This will be the first accessory for me on the layout. I am waiting for the crossing gate to arrive, shipped out to me a few days ago but I have the m84 in hand already. Thank you in advance.
Brian
thanks 1 user liked this useful post by bgemski
Offline bgemski
#2 Posted : 16 May 2025 15:52:01(UTC)
bgemski
I forgot to mention and to clarify the system I am operating the layout with is a Marklin CS3 +, no automation.
#3 Posted : 16 May 2025 16:22:46(UTC)
Brian, did you get the complete system with the relay box? The M84 is programmable for momentary and delay or constant switching. The instructions should explain how. I only use M83's for turnouts. My crossing lights are Viessmann and use the flasher unit so I just use a two pole rocker switch. No automatic trigger.
Offline bgemski
#4 Posted : 16 May 2025 18:38:29(UTC)
bgemski
To be honest I'm not sure I don't have it in hand yet. That being said I like the idea you have using a toggle switch. Would you happen to have a wiring diagram for your system?
#5 Posted : 16 May 2025 22:39:18(UTC)
No, I didn't draw one. The flasher unit has labeled negative (ground )and positive terminals and it is easy to keep the wiring in that order to the switch and the lights. The switch is on the positive wire between the flasher and the lights.
Offline bgemski
#6 Posted : 16 May 2025 23:03:11(UTC)
bgemski
I will keep this option in mind. I am really liking this idea. My m84 is still available for use plus, i just looked, I have available inputs on my m83. When it lands I will poke away at it and see what happens.
#7 Posted : 16 May 2025 23:34:44(UTC)
Hi Brian
The Viessmann 5100 is a unit capable of:
- analog operation using contact tracks You dont need anything else
- digital operation suing a Märklin 60832 (same as for turnouts) or the Viessmann equivalent
Since you say no automation you may not have a feedback module (60881)
These are used to detect a zone (around the level crossing) and associate an event on your CS3+ to open / close the gate depending on the occupation of the track section
Offline bgemski
#8 Posted : 19 May 2025 03:41:43(UTC)
bgemski
Jean,
Thank you for the information. I have space in my last m 83 I could hook up to. For some reason I just assumed I would need the m84. Not sure what I was thinking to be honest. To answer another question no I do not have a feedback module. I should have the crossing gate in hand sometime this week. I will use the m 83 with the crossing gate and see what happens.
Thank you guys for helping out. Much appreciated!
Offline Johnvr
#9 Posted : 19 May 2025 08:54:42(UTC)
Johnvr
Hello Brian,
The 5100 set comes with an electronic control box included.
You connect your power power to the electronic control box, and then connect the flashing lights and boom sensors to the box (both up and down positions).
Then it all operates from the equipment provided.
Activating the operating procedure is done via a sensor in the train track.
You can use a Marklin 24994 Circuit Track to activate the procedure.
(The Marklin 24994 can be connected to an outside circuit independent of the Marklin current supply)
No need for Marklin equipment M84 nor M83 nor s88.
For information :
A friend of mine has a Viessmann 5100 set where the electronic control box is defective.
I have assisted him by programming an Arduino micro-controller to operate the rail crossing.
Offline bgemski
#10 Posted : 20 May 2025 21:01:53(UTC)
bgemski
Hi Johnvr,
I'm kind of confused mine doesn't have an electronic control box included. From what I can tell it is factory sealed as well. The set is from eBay, but looks like new old stock, and the packing looks to be original. Is there two versions of the 5100?
Sincerely
Brian
#11 Posted : 20 May 2025 22:44:50(UTC)
I think so Brian. The 5201is for 3 rail tracks. The wiring diagram and manual can be downloaded.
It says that you only need a contact track. A simulated wood between the tracks filler is available.
Offline bgemski
#12 Posted : 21 May 2025 01:13:50(UTC)
bgemski
Viessman 5201 is the transformer, however I'm thinking I may have goofed with the 5100
Offline bgemski
#13 Posted : 21 May 2025 01:38:56(UTC)
bgemski
Here is a picture of what I received:
Offline bgemski
#14 Posted : 21 May 2025 01:41:04(UTC)
bgemski
Front of the box:
Offline Johnvr
#15 Posted : 21 May 2025 21:03:29(UTC)
Johnvr
Hello Brian,
I have unfortunately given some incorrect information to you.
I was thinking of the Faller 120171 Rail Crossing, not the Viessmann 5100 Rail Crossing.
I apologise for making that mistake.
So, I am not familiar with the Viessmann 5100 Rail Crossing.
Let me add that the M84 is a very useful tool, and can most likely be used.
I would use a M84 in conjunction with s88 feedback module connected to your CS.
The M84 can be programmed digitally to have relay outputs to be open for a number of seconds and then to be closed.
This can be used to allow the booms to go up, and then to go down, by using an external power source.
I'm not exactly sure whether the booms have end point shut-offs and whether these can be incorporated.
Offline bgemski
#16 Posted : 21 May 2025 23:47:40(UTC)
bgemski
Hello Johnvr,
Lol no problem I was so confused, which is really easy for me to be honest. I'm thinking of the m83 or I have a completely new uninstalled m84. Either way one or both should work. In the next few days I will dive into this project.
Thank you though for the information! It is much appreciated.
Sincerely
Brian
This page was generated in 0.444 seconds.
