Offline philippe99
#1 Posted : 07 May 2025 15:36:58(UTC)
philippe99
Hello the community.
On a 2nd hand site, someone is selling Marklin 7339 as traffic signals.
On one of the photo, I only see two yellow cables coming out of the signal body.
Moreover, it is sold with an interruption M section.
So I guess, it is a kind of warning signal (or repetition signal) that, ok, stops the traction but if driven by another device, like another traffic signal.
Q1: am i right ?
Q2: can i use such kind of signal to allow traffic to/from a parking area (like a locomotive shed) by just driven it by a control console, like a 7072 one ?
In a classical traffic signal, the signal gives/cuts the traction power (red cables) on both sides of an isolated couple of tracks.
But here, is it a simple on/off switch ?
Thx
Phil
thanks 1 user liked this useful post by philippe99
Online marklinist5999
#2 Posted : 07 May 2025 15:43:11(UTC)
Haupt means head, so I've seen the word hauptbahnhoff, which is main station. So it can be a station entry home signal?
Offline ocram63_uk
#3 Posted : 07 May 2025 16:35:59(UTC)
ocram63_uk
There is a Marklin Signa Booklet that explains all of these things. Look in there, please. I believe it is a signal that sits before the actual signal to tell the driver what the actual signal is se to.
Offline philippe99
#4 Posted : 07 May 2025 17:02:31(UTC)
philippe99
....sits before the actual signal to tell the driver what the actual signal is se to.
Agree. Like the warning signal 7187 ahead of the home signal 7188.
But these are warning signals. The switch of traction current is let to the home signal after.
Here the 7339 can cut the traction current.
So my idea to use it with a controle console just to cut the traction signal in all of my parking area, like a center conducteur insulator (5022) but that I control from my console.
Phil
#5 Posted : 07 May 2025 17:15:04(UTC)
As I understand it, the 7339 is finger-operated without solenoid. So "remote control" is limited by the length of your arm.
Offline philippe99
#6 Posted : 07 May 2025 17:15:09(UTC)
philippe99
Ok, Ok, I found this image
7339 is a manually operated cheaper vesion of the 7188.
And the yellow cable just power the lights.
Phil
thanks 2 users liked this useful post by philippe99
Offline ccranium
#7 Posted : 07 May 2025 18:30:56(UTC)
ccranium
Hi Phil,
When it was introduced in 1971 the catalog said it was controlled "by manual operation and control the current to the center stud of the piece of track connected to the signal" and "sold with the "additional piece of track 3-1/2" long, with interupted (sic) center studs". So to have a block section at the signal one needs to use both pieces of the track shown in your image; additional tracks can be placed in between I suppose for a longer block. I hope that helps some.
Brian
Offline philippe99
#8 Posted : 07 May 2025 20:06:52(UTC)
philippe99
Brian
Totally right !
So I can create a complete parking line of track to park a complete train !
See this thread on the forum. Sorry for not discovering it before .
Thx phil
Offline mvd71
#9 Posted : 08 May 2025 00:19:01(UTC)
Try using google translate before you shoot from the hip!
#10 Posted : 08 May 2025 08:51:47(UTC)
"Haupt" means "main" in this context.
Due to the size of the light bulbs, this signal was the only type, used as entry signal, exit signal, block signal.
Kopf also means head. As in Kopfbahnhof (terminus station).
Offline 60904
#11 Posted : 27 May 2025 22:38:15(UTC)
60904
Germany: Hauptsignal (showing red Hp0) or green (Hp1) or green and yellow Hp2) can be translated as Homesignal. Green (Hp1) and yellow (Hp2) for reducing speed. Vorsignal is Distant Signal showing the driver what can be expected next- red or green or green and yellow. A distant signal can show 2 yellow or 2 green or yellow and green.
Martin
thanks 1 user liked this useful post by 60904
Guest (5)
This page was generated in 0.396 seconds.
