Offline philippe99
#1 Posted : 20 April 2025 12:54:34(UTC)
philippe99
Hello.
I run M tracks, but I've the opportunity to buy a complete set of K tracks: +/- 140 mixed tracks parts.... ! no powered ones !.... no sure about railway switches.
Global package around 60 euros (For me, K and M are equivalent, so I think the offer is good.
My idea is to have my outer loops based on K tracks (no signal but switches to enter M inner circuit), while the internal part of my layout (locomotive shed, stations, ...) will be based on M tracks.
Question 1: Do transition parts exist ?
Question 2: Can M powered part power K circuit ?
Question 3: for switching for K circuit to M one, is the following idea "K_switch -> transition part -> M track" a option ?
(Nb: sorry for my english... when I say 'K switch', I think for instance to part 2262 of marklin K stuff)
Thx
Phil
Online kiwiAlan
#2 Posted : 20 April 2025 13:47:23(UTC)
1. Yes, I can't recall the catalogue number off hand, but they do exist. I would hope you get some as part of the complete package seeing they have mixed M and K track.
2. Yes, there is no problem with one type powering the other.
3. You wouldn't normally do that, but if needed it can be done.
Offline philippe99
#3 Posted : 20 April 2025 14:37:04(UTC)
philippe99
Thx.
So what is the best workflow to transition from K to M through switches ?
Phil
Offline cintrans
#4 Posted : 20 April 2025 14:41:58(UTC)
cintrans
Aruba
The transition track for M to K is part # 2291, a 180 mm long straight track.
Jean-Pierre
Offline cintrans
#5 Posted : 20 April 2025 14:47:41(UTC)
cintrans
Aruba
Thx.
Phil
I think this will be difficult to do with only a inner and outer loop, you can not connect a K-switch to a M-switch together, and as said the only transition part available is a straight 180 mm track.....
Jean-Pierre
Offline Bill L
#6 Posted : 20 April 2025 15:59:33(UTC)
Bill L
Make sure it is the 2200 series K tracks with SOLID METAL rails. Stay away from the 2100 series that have pressed folded rails that change color more easily when slow corrosion occurs and turns darker color.
thanks 1 user liked this useful post by Bill L
#7 Posted : 20 April 2025 16:21:14(UTC)
I started with M track. In the 1980s I got some K track because you could get larger radii which was important for me to show off my 1/87 Roco coaches. I had a parade layout of R4 and R5 curves with an inside track of M track R2 and R1. By skipping R3, I was able to put the adapter track between the two. I used the M track as a local/regional line and the K track was the mainline. This was all set up as a teppichbahn on the floor from time to time. These days, I am almost exclusively using C track. I went back to the K track when my original C tracks starting cracking, but the newer ones (post-2005) are much less prone to deterioration. For digital operation, the combination of tracks can be problematic, as transitions can cause weak spots that can be damaged with constant power supply. I had one K to M track where one of the little metal pins somehow touched the metal of the M track and this caused a little heat damage without the transformer tripping.
Offline philippe99
#8 Posted : 20 April 2025 20:55:19(UTC)
philippe99
Good info. I need to call the vendor. Thx
Phil
Offline philippe99
#9 Posted : 20 April 2025 21:02:42(UTC)
philippe99
Ok, it is clear now : Kswitch__transition2291__(eventually one M straight like 5106)__Mswitch to enter my internal M circuit.
Phil
thanks 1 user liked this useful post by philippe99
This page was generated in 0.510 seconds.
