Offline MALAVIKA
#1 Posted : 20 March 2025 08:31:44(UTC)
MALAVIKA
India
IIcannot locate the lever/switch to change from
Catenary to Mtrack rail.
Please help.
I am from India and age 82.
Thank you,
Kumar India
#2 Posted : 20 March 2025 10:37:02(UTC)
Hello Malavika
On my 3015 (Koll's version10) there is no manual lever for direction change.
There probably has been on earlier models but around 1962, Märklin started to remove those levers for cost and detailling reasons.
In case you are interested, here is the exploded view diagram by Märklin where I cannot see any lever
https://www.maerklin.de/service/...r.php?artikelnummer=3015
#3 Posted : 20 March 2025 12:07:06(UTC)
On the explosion diagram linked by Jean, look for #25 "Umschalter" close to the motor.
I assume that's the switch that chooses between catenary and centre rail.
Offline Michael4
#4 Posted : 20 March 2025 23:26:31(UTC)
Michael4
You are correct but there is a vertical metal lever/bar that attaches to it and protrudes out of the bottom of the loco's body. On the diagram I think it is number 29. Marklin 208870
https://www.ebay.ph/itm/202659582218
I only know about it because it was missing on my 3015 which had been modified for catenary only use.
Offline scarfo
#5 Posted : 21 March 2025 04:32:48(UTC)
scarfo
India
Hi Kumar
As i said in my email, there should be a vertical bar that looks like a step painted red. I have not seen your loco in the flesh so maybe its missing if the previous owner removed it as they only wanted catenary feed. Send me a picture of both sides of the loco and i will point it out if i can
Regards Charles
Offline Br502362
#6 Posted : 21 March 2025 08:14:29(UTC)
Br502362
And #29 is the lever which moves the #25.
Åke
thanks 3 users liked this useful post by Br502362
Offline ktsolias
#7 Posted : 22 March 2025 23:27:21(UTC)
ktsolias
Hi here is a picture of the lever
is no 29 in the plan
Costas
Offline Peter S
#8 Posted : 23 March 2025 15:18:11(UTC)
Peter S
actually your picture is mirrored and the lever is on the left side.
This page was generated in 0.359 seconds.
