Offline rinderkn
#1 Posted : 09 February 2025 16:55:55(UTC)
rinderkn
I have programmed an ESP32 that connects via WiFi to the local network, where the Märklin CS3+ and the PC with Rocrail are connected. The ESP32 sends S88 events via UDP to the CS3+ IP on port 15731. The ESP32 simulates a feedback contact by switching its value every 2 seconds (device 0, contact 2). On the CS3+ display, I can see that the feedback contact value automatically changes every 2 seconds (from gray to yellow to gray, etc.). This means that communication from ESP32 -> CS3+ seems to be working.
I have also connected the CS3+ to Rocrail (via TCP), and bidirectional communication between CS3+ <-> Rocrail is also working: When I manually change the feedback contact values on the CS3+, the feedback sensors in Rocrail are updated accordingly (16:35:14 9999 sensor 0:2 state=0 value=100, 16:35:13 9999 sensor 0:2 state=1 value=100, ...). So far, so good.
However, what is not yet working is that the events sent by the ESP32 do not reach Rocrail via the CS3+. Somehow, the communication ESP32 -> CS3+ -> Rocrail is not working.
Does anyone have an idea what could be causing this?
Offline rinderkn
#2 Posted : 09 February 2025 18:19:25(UTC)
rinderkn
Problem got solved thanks to this reply (using TCP both CS3+ and Rocrail get updated!): https://www.stummiforum....-Rocrail.html#msg2780464
#3 Posted : 09 February 2025 18:49:25(UTC)
I have no idea what ESP and TCP etc is. Model rail is becoming a different hobby for me but good that he problem was solved.
Offline nhumps
#4 Posted : 12 March 2025 09:04:45(UTC)
nhumps
i'm curious; are you using the built in rocrail:wio functionality here? or have you rolled your own?
Offline osoraku
#5 Posted : 12 March 2025 10:01:19(UTC)
osoraku
I'm not sure what Mike is using, but the MBUS controller type has this functionality in Rocrail - I use it.
Osoraku
This page was generated in 0.238 seconds.
