Offline sanjiv
#1 Posted : 10 March 2025 12:02:30(UTC)
sanjiv
India
Hi everyone. Im Sanjiv from India and have the following problem configuring S88.
I have already a Link 88 connected to the CS3 Plus and all contacts working fine. I recently connected a S88 directly to the RJ45 port at the bottom of the CS3Plus and added 4 contacts under GFP3-1. Unfortunately none are working in fact not responding at all. How can we configure this.
Can some one please help ion this issue. Am attaching some photos IMG_3917.jpeg
thanks Sanjiv
Offline BenP
#2 Posted : 10 March 2025 12:48:52(UTC)
BenP
Try connecting s88 to l88 with supplied cable. (L88 needs power supply to work.)
Ben
Ben van der Pluijm--
Offline PerR
#3 Posted : 10 March 2025 13:08:00(UTC)
PerR
you will need to connect the ground pin on the S88 AC (invertet T) to the brown wire to the tracks for the first S88 AC connected to the Rj45 connector at the bottom of the CS3+.
Your configuration looks good.
Per
thanks 1 user liked this useful post by PerR
#4 Posted : 10 March 2025 13:19:07(UTC)
Hi Sanjiv
I think the issue is related with updating bus lengths on LinkS88
You have one external 60883 that you seem to have programmed correctly
What about the INTERNAL LinkS88 included in the CS3Plus 60216? Have you updated the number of S88 modules connected DIRECTLY to the CS3 Plus?
Check in the LinkS88 tab
Sorry, I cannot be more precise as I have a CS3 60226 with an external LinkS88
It seems to show on one of your screen the number of S88 modules connected directly to the CS3Plus
See the red-circled zone
You MUST also connect the upsidedown "T" of the directly connected S88 to the "O" of the digital power output
Offline sanjiv
#5 Posted : 13 March 2025 12:01:01(UTC)
sanjiv
India
Ben
Hi I tried that but still no response. Perhaps I cannot figure out what should the settings be. Any advise on settings
Sanjiv
Offline sanjiv
#6 Posted : 13 March 2025 12:04:27(UTC)
sanjiv
India
Hi Sanjiv
Hi Jean, yes I have one S88 AC connected to the internal Link included in the CS3plus 60216. The no of modules connected to the CS3 Plus is at 1.
What should the configuration be, I cannot figure out.
Sanjiv Keshava
Offline sanjiv
#7 Posted : 13 March 2025 12:06:21(UTC)
sanjiv
India
Per
I have done just that. Connected the inverted T on the s88 to the track 'O' But still I get no response. I can't seem to get the right configuration
Sanjiv
Offline sanjiv
#8 Posted : 13 April 2025 07:33:00(UTC)
sanjiv
India
Hi all, Thanks for your responses. I finally figured I had a defective S88. Got a new one and all working perfectly well
Sanjiv
#9 Posted : 13 April 2025 09:25:54(UTC)
Sanjiv
Did you find out what the defective S88 was the problem?
You can open the box and tried to figure out if there was bad contacts for example.
This page was generated in 0.408 seconds.
