Offline rickjames84
#1 Posted : 28 February 2025 22:28:20(UTC)
rickjames84
I bought the Marklin 2862 set, and the DB Locomotive BR111 is analog? How do you convert the locomotive to from analog to digital?
Thanks in advance!!
thanks 1 user liked this useful post by rickjames84
#2 Posted : 28 February 2025 23:07:27(UTC)
I remember that set when new. I have the same locomotive, item 3311. It had a Siemens electronic reverse unit. It has plug in type socket light bulbs. My then dealer installed a Delta decoder.
What you with need depends on if you want sound. You can leave the motor alone, and just use the digital decoder for classics. It doesn't have speed control acceleration and braking compensation. Otherwise, you will have to change the motor to a 5 pole armature commutator and a field magnet vs. keeping the 3 pole armature and the field coil windings. If you want LED lights, you will also need to change the sockets and the bulbs and add resistors.
Offline Ross
#3 Posted : 28 February 2025 23:14:39(UTC)
Ross
Hi Rick,
Vist my web pages see link below and select "My Tips Section" then do a search for 2859 which is a similar version to 2862.
Let me know how you go with your project.
Thanks in advance!!
Ross
Offline rickjames84
#4 Posted : 28 February 2025 23:17:26(UTC)
rickjames84
Thank for the reply I don't want sound i heard that can be complicated. I was thinking the standard digital decoder maybe the 4 pin or 8 pin, I saw from Marklin. This locomotive has the LED lights.
Offline rickjames84
#5 Posted : 28 February 2025 23:27:36(UTC)
rickjames84
Hi Rick,
Thanks in advance!!
Thanks for the suggestion and very detailed, im not confident in doing by myself.
Offline rbw993
#6 Posted : 28 February 2025 23:42:25(UTC)
rbw993
Hi Rick,
Send it to Scott Helmut's Hobbies, http://www.helmutshobbies.com/, or Robert at http://www.rjftrains.com.
I've used both for conversions and was satisfied with the result.
Roger
Offline Ross
#7 Posted : 28 February 2025 23:46:13(UTC)
Ross
Hi Rick,
You could look for someone who might be able to make use of my article to help you.
Ross
Offline rickjames84
#8 Posted : 01 March 2025 09:38:47(UTC)
rickjames84
Hi Rick,
I have that exact model you did the conversion manual for.
Offline ocram63_uk
#9 Posted : 01 March 2025 12:14:47(UTC)
ocram63_uk
@Ross, on my phone I can't see the link to your website
#10 Posted : 01 March 2025 15:17:46(UTC)
Led's back then? I thouight only in certain cab control cars and rear coach markers.
Offline Ross
#11 Posted : 01 March 2025 23:15:53(UTC)
Ross
Hi Marco,
I use google chrome viewer and can see the WWW box below my post and by clicking on WWW it will goto my web pages.
Works on my mobile phone ok.
Ross
This page was generated in 0.319 seconds.
