Offline rabtab
#1 Posted : 15 February 2025 18:02:37(UTC)
rabtab
Hi. Can anyone let me know where I can find a parts list for the Marklin 37786 ICE 3 BR 406 set? Also, when I run the set the second "engine" does not light at all, inside or the headlights. I am not using the correct transfomer I learned, so could that be it?
Offline dickinsonj
#2 Posted : 15 February 2025 18:13:17(UTC)
If the other coaches in that set are working normally the problem is probably not with the transformer. I would check the pins in the connector for that power car which is not working properly. Also make sure that the connector is mating securely with the coach it connects to.
BTW, I spent about 18 months at Ft. Meade myself, and welcome to this great forum!
#3 Posted : 15 February 2025 20:53:11(UTC)
https://static.maerklin....bb1873fcb41434542638.pdf
Parts list is at the end of the booklet
Offline rabtab
#4 Posted : 16 February 2025 14:41:22(UTC)
rabtab
https://static.maerklin.de/damcontent/f5/ac/f5accf5eeea2f0dfd2856fbb1873fcb41434542638.pdf
BigGrin Thanks very Much Mike!
Offline rabtab
#5 Posted : 16 February 2025 14:44:33(UTC)
rabtab
Thanks! I switched around the order of the coaches and the light came on briefly, so your tip on the connections is spot on. I'll clen them up a bit to see if that helps. I did order the correct transformer yesterday. I noticed this set ran very slowly with the older Marklin transformer I have (Marklin "Super) even though the difference in volatage is only 2 V.
thanks 2 users liked this useful post by rabtab
Offline dickinsonj
#6 Posted : 16 February 2025 14:59:03(UTC)
Good, you are making progress!
I would also check the connector on the coach that the problem power car connects to. Cleaning is a good start and if you still have problems do continuity checks on the connector wiring. I don't have this model, but connectors of that type can get sloppy after repeated connects/disconnects, particularly if they have been mishandled in the past.
This page was generated in 0.317 seconds.
