2 Pages12>
Online jonas_sthlm
#1 Posted : 12 February 2025 11:05:25(UTC)
jonas_sthlm
Has anyone noted any information on any upcoming updates or maybe everything is perfect?
I still have M4 protocol turned off on all ESU decoders....
#2 Posted : 12 February 2025 11:50:45(UTC)
Hi Jonas
I have made a search in German forums to check for any leaks about an update in preparation for the CS3 and found nothing.
As you know the last one was 2.5.2 released in Feb 2024 to correct bugs on the 2.5.1 released in Nov 2023.
It is very likely that Märklin is working hard on the replacement of the CS3 (released in 2016 and already 9 years old)
As a reference, the CS2 (60213) was released in 2008 and lasted until 2016 (8 years) so the replacement is already past due.
Sorry for my simple reasonning and recap of things you already know.
I wouldn't be surprized of a new unit without screen (screen is costly and always too small) but with much more processing power and train follow-up (it knows where trains are in real time like Rocrail and its competitors do).
So until that release of a new unit, I am expecting CS3 updates will be scarce
BTW: I have to hats off to you about disabling the M4 protocol on ESU decoders is a very wise decision. I should have done this because CS3 update 2.5.1 garbled the only ESU decoder (Loksound 5 mini) I had and is now useless because a lok Programmer is needed to correct the mess this 2.5.1 release has created (which I have no intention of purchasing).
Online jonas_sthlm
#3 Posted : 12 February 2025 12:15:02(UTC)
jonas_sthlm
I find it a bit hard to believe that a new replacement to CS3 will come anytime soon, considering there was barely enough budget to expand the C track system.
They needs to be understood that it cannot incorporate a full PC application like Rocrail or TC so stick to a more basic controls. It feels like they had difficulty providing even a small update, such as firmware for the decoder and system English translation.
Over time, M has changed their digital equipment, but we still use the old ESU USB hardware with the Programmer software to this day.
Can you clarify what you're referring to with "damage 5 decoder"? Are you talking about some kind of hardware failure and did you find any information to fix decoder....
I had a 5 MKL where AUX 3 and 4 output suddenly stopped functioning but i try to reset it and upgrade with latest FW with Programmer without any success.
I received a response from the manufacturer of the PCB where the decoder is mounted. They stated that the two LEDs connected to AUX 3 and 4 could not be damaged and I believe that too.
Either something crap from ESU or CS3 has create an issue with the decoder.
I don't bother try contact ESU because it's like a black hole in space with an echo millions of years later.
Offline bph
#4 Posted : 12 February 2025 12:24:39(UTC)
They are working on an update, so probably noting very immediate, but hopefully in 1-2 months or........
Online jonas_sthlm
#5 Posted : 12 February 2025 13:00:18(UTC)
jonas_sthlm
Is it a hypothesis because they need their new locomotive icons for Intermodellbau Dortmund in April?
Offline bph
#6 Posted : 12 February 2025 13:25:16(UTC)
no hypothesis. the information was on an actual software update, and not a minor update with icons etc
#7 Posted : 12 February 2025 13:52:41(UTC)
It seems Märklin have some problem by update system because due to the cost and solve technical problem too.
Customer write some problems with the soft program and use VNC viewers.
Of course with the PC program which are waste for me if you have already screen view on the CS3.
If Märklin will show up a new digital system like a black box and use mobil/tablet as cab control okey!
A new update will soon or later show up anyway but when?
#8 Posted : 12 February 2025 14:05:56(UTC)
There was something in an announcement recently (before Christmas IIRC) which implied there would be an update in the foreseeable future. I can't recall what it was I was reading at the time, but there was a definite inference on an update when 'reading between the lines'.
Offline bph
#9 Posted : 12 February 2025 14:26:54(UTC)
yes, there was some information earlier, but the above information is recent information from Feb 2025. However, if they encounter some issues it will be delayed......
Offline rhfil
#10 Posted : 12 February 2025 14:49:52(UTC)
rhfil
Every year Marklin adds to its line of mfx+ locos which is a unique feature of Marklin locos and requires the Marklin CS3 to take advantage of. But there is little information out there about it and few modelers use it. One of the problems is that it requires a straight run as it completely ties up the CS3 screen. I think any update will be aimed at increased use of the mfx+ feature otherwise why the investment in it.
Online marklinist5999
#11 Posted : 12 February 2025 14:57:39(UTC)
There is a USA webinar today, so maybe we will find out something more? I don't connect my CS3 to the web usually until I know there are updates. Too many hackers out there.
Online jonas_sthlm
#12 Posted : 12 February 2025 15:07:52(UTC)
jonas_sthlm
How many is really playing with train cabin (mfx+) today?
The only good thing is that the function button arrive automatic into the device and some other CV.
When it comes to VNC viewers I only using that sometime for maybe adding lok icons and function button but that can be done with web interface.
To speed up the CS3 system i reduce the icon other vice the mobile slows when selecting someone.....
I think it will crash before I even get to half of all the locomotives RollEyes
thanks 3 users liked this useful post by jonas_sthlm
#13 Posted : 12 February 2025 15:33:51(UTC)
I like the cab driving feature, occasionally, but only while running one train. It is different, because of the truer to prototype acceleration and braking. I think the only improvement the CS would need is better graphics for it. Like Roco Z-21 has.
Offline rhfil
#14 Posted : 12 February 2025 17:25:51(UTC)
rhfil
I heard a story/rumor that when the first mfx+ locos came out they were shipped with the "World of Operations" selected and the locos would soon run out of water and stop. That resulted in their being sent back. One of the odd features is the ability to set maintenance locations on your layout. If that were tied somehow to functioning maintenance facilities such as water towers or coaling stations it would improve the reality. It appears that might have been planned but never completed. One of the glitches I found is that once you select the ability to locate maintenance facilities you can't really unselect them.
Offline Dirtboy
#15 Posted : 12 February 2025 21:27:58(UTC)
Dirtboy
Hi Jonas
...It is very likely that Märklin is working hard on the replacement of the CS3 (released in 2016 and already 9 years old)
As a reference, the CS2 (60213) was released in 2008 and lasted until 2016 (8 years) so the replacement is already past due...
This is why I'm a bit hesitant to buy a CS3; I'm sure once I get it a new version (CS4?) will be released...
thanks 2 users liked this useful post by Dirtboy
#16 Posted : 13 February 2025 01:19:38(UTC)
I think the CS 3 is great and even if a new one is released, the current one will be supported with updates for a long time.
As for the world of operation settings, you can select with or without fuel, sand and water consumption. Without consumption, the loco will not stop.
Some have suggested that a virtual type of control system is on the horizon, but I don't think I would care for it. I'm not a video gamer in the least.
Offline rhfil
#17 Posted : 13 February 2025 02:31:13(UTC)
rhfil
I model only steamers from eras 1/2. But I tried nearly every mfx+ locomotive in World of Operations just to see the different controls. The deadstick requirement of the electrics and diesels nearly drove me crazy until I figured out what it was. And I ran out of water a number of times with my steamers. But it taught me just how demanding running a steamer was. And when I first experimented with it stopping the locomotive on an exact spot was necessary and difficult. That requirement no longer exists.
#18 Posted : 13 February 2025 11:34:20(UTC)
When Märklin present a new update for the CS3, make sure after the upgrade your CS3 work.
I recommended you to check.
By the way...i have never used "world of operation" because i want to control my locomotives by self and it´s just only model railway.
If i want to use train games i do it via PC games instead.
Not with the CS3!
#19 Posted : 13 February 2025 13:28:39(UTC)
Goofy, when the updates are complete, the CS 3 restarts and it is obvious if it works. With world of operation you still control the locos by self. It's just more like driving a real life train.
Offline BenP
#20 Posted : 13 February 2025 13:38:04(UTC)
BenP
Instead of a cs4, which will be pushing $1000, a cs3 mini would be a good addition. Same innards and ports, but without touch screen and knobs. And with wifi. Users use VNC or pc software for visual control. Same parts, so $400 or less seems reasonable.
Ben
Ben van der Pluijm--
Offline rhfil
#21 Posted : 13 February 2025 15:13:22(UTC)
rhfil
When I receive notice of a CS3 update I first save a dated copy of the existing operating system on both the CS3 and a thumb drive. That gives me a restore in the event I do mot like the change.
#22 Posted : 13 February 2025 17:06:28(UTC)
I want a screen!
Offline LeoArietis
#23 Posted : 13 February 2025 17:27:22(UTC)
LeoArietis
Märklin should do the sensible thing and go with open source. But I guess they are to stubborn.
Current layout:
The former project:
thanks 1 user liked this useful post by LeoArietis
#24 Posted : 13 February 2025 18:18:55(UTC)
The next update for CS3 due April 2025 - Marklin.
No plan for CS4.
#25 Posted : 13 February 2025 19:13:56(UTC)
Linux is open platform Leo. Marklin uses it.
Online jonas_sthlm
#26 Posted : 13 February 2025 20:40:51(UTC)
jonas_sthlm
No plan for CS4.
Nice that they provides which year ThumpUp
#27 Posted : 13 February 2025 20:42:14(UTC)
But that is only the underlying operating system. The stuff that does the real work is not open platform, but proprietary Marklin code.
Online jonas_sthlm
#28 Posted : 13 February 2025 21:32:15(UTC)
jonas_sthlm
As I have said before, there should be more openness and transparency about the existing problems and the measures being taken for the next update.
There shouldn't be any surprises like last time with the ESU 5 decoder, as they should have had time to test it.
Their updates releases are more like a Kinder Surprise Egg RollEyes
Dose any know if Uhlenbrock is the provider of digital hardware "especially decoder" and service development?
Offline Kanga
#29 Posted : 14 February 2025 02:29:15(UTC)
Kanga
My screen hasn't worked (GUI software issue) for a couple of years/ many updates. Marklin says to send it back to them. I just keep using a laptop.
Karl
Online jonas_sthlm
#30 Posted : 14 February 2025 08:41:26(UTC)
jonas_sthlm
No plan for CS4.
I am more concerned that it doesn't end up like a joint project with PIKO.
#31 Posted : 14 February 2025 09:37:18(UTC)
Not sure and that´s way i recommended CS3 users to check in case.
World of operation in the CS3 is a small PC game which are waste of time for me.
If i want a PC train games i do it via PC.
Offline Pasquiles
#32 Posted : 14 February 2025 12:48:38(UTC)
Pasquiles
Luxembourg
I do not see business reason to have a new CS from Märklin point of view.
From the user side I cannot find any functionality that I am really missing, specially after the release of the new wireless mobile station. And the re-release of the app web interface for the tablets and telephones.
thanks 4 users liked this useful post by Pasquiles
Offline dickinsonj
#33 Posted : 15 February 2025 01:23:49(UTC)
I agree Pasquiles.
I think they did a good job selecting the hardware for the CS3 and that they can do most near term upgrades with better software. But of course I am a software guy, so I see a fix for every problem there. BigGrin
#34 Posted : 15 February 2025 13:40:33(UTC)
Jim, I think you are right about that. Always a possibility for change or improvements. Vehicle screens and apps for example. Our son was doing that for Ford in one of his group rotations. There were features that lessee and owners either wanted that weren't included in the model year or ones that were removed in consecutive models.
I don't care for some of the changes our car has. Examples like adding the climate control system to the screen. I have to take my eyes off the road to adjust the temperature or set the rear defrost. At least fan speed is automatic. Also the heated seats and steering wheel are now on screen. It's a 2024. The 2020 still had buttons. Additionally, the remote start features were changed, Only the driver's seat heats up when you use it. I don't know if that is owner settable or not. The manual is also either on screen or online.
I prefer it printed in a book. Also the rear doors can not be just opened when locked by touching the door handles. Only the front doors. The puddle lamps on the mirrors are no longer, and the key touch pad in the driver's door pillar. The power seats have fewer movements as well. They only raise up or down. You can't only raise knee bolster rake. Not best for trips. Cost cutting for production while increasing the prices.
Offline bph
#35 Posted : 17 February 2025 23:03:12(UTC)
I like the CS3 user interface and form factor. and I'm glad that the CS3 has its own screen that runs on Linx and that I'm not depending on Microsoft, google or apple etc to run my trains.
a black box solution is not for me, but I recognise that others prefer that solution. so when/if Markin releases the CS4 I hope they release it in two versions one with and one without a screen.
but back to a planned update, and some speculation, I would not be surprised if we see a small update first, with "only" new loc icons and new decoder firmware files, especially if the main update is delayed. And I prefer them to iron out the bugs before the release even if that means delaying the release.
thanks 5 users liked this useful post by bph
Offline Copenhagen
#36 Posted : 18 February 2025 09:58:20(UTC)
Copenhagen
I agree with bph above. Thought about commenting about the matter some time ago. My thoughts are that screens are likely dirt cheap these days and wont contribute much to the price of a product, and that the market isn't big enough to justify two versions af a new control station.
thanks 3 users liked this useful post by Copenhagen
#37 Posted : 18 February 2025 13:26:29(UTC)
Yes I agree we dont need two versions. A newer version with a slightly larger screen would be fine. I dont need another monitor taking up room on the desk or any other hard or software as a CS3 does all I and probably most will ever need.
I can see the day when all we will have is software with no actual models but trains running on a large TV type screen. OK not serious but would not be surprised if the youngsters of the future will just run a layout on their phones while walking back from school.
thanks 5 users liked this useful post by David Dewar
Offline dickinsonj
#38 Posted : 18 February 2025 14:10:27(UTC)
I could see that happening as we blur the line between what is real and what is an illusion.
Luckily that won't happen right away because at that point all of the magic of model trains would be gone for me David.
#39 Posted : 18 February 2025 15:06:12(UTC)
That would be an opportunbirty for A.I. developers. When my son in law who is a web developer aske me if I'd be interested in a vurtual model train layout tjhat could have all of my trains, then I could sell my collection, I told him if that were available, then no younger people would want to or have a need for collecting tangable models. So no, I would not want that. For me, there would be no hobby.
Offline mbarreto
#40 Posted : 18 February 2025 15:55:36(UTC)
mbarreto
The current train simulators are already filling part of the needs of ones that lean more towards that.
Miguel
Mostly Märklin H0.
#41 Posted : 18 February 2025 16:41:58(UTC)
Yes, but I have only seen simulators that look animated.
#42 Posted : 18 February 2025 21:43:56(UTC)
An AI virtual train program will kill and terminate companies who produce model railway toys.
To add this in the CS3...Märklin should made a bigger screen! LOL
Online jonas_sthlm
#43 Posted : 21 April 2025 10:33:17(UTC)
jonas_sthlm
No plan for CS4.
Now we are approaching the end of April...
I still have the feeling that something is wrong with GFP3: (12.113) that causes it to overload at startup Huh
thanks 2 users liked this useful post by jonas_sthlm
Online jonas_sthlm
#44 Posted : 09 May 2025 16:11:50(UTC)
jonas_sthlm
Power supply setting in case of voltage error
With the GFP2 update to version 3.95 and the GFP3 update to 12.113, a feature that had previously received little attention has been activated for security reasons: monitoring of the input voltage supplied by the power supply. This affects all the devices listed above. The core goal is to reliably detect incorrect voltages and overcurrents in order to provide timely protection by shutting down the system if necessary.
The correct selection of settings is listed in the tables.
Online jonas_sthlm
#45 Posted : 10 July 2025 12:26:18(UTC)
jonas_sthlm
Have we heard anything new about the upcoming (April) update?
#46 Posted : 11 August 2025 14:28:07(UTC)
Email from Marklin customer service.
Unfortunately, There have been delays in the development of the update, We are planning for autumn, But of course we cannot make any definite promises yet.
Online jonas_sthlm
#47 Posted : 29 October 2025 15:02:16(UTC)
jonas_sthlm
Anyone heard or read anything on this topic?
It feels nice to be aging in step with the digital development pace of the CS3 LOL
#48 Posted : 29 October 2025 19:39:52(UTC)
You have just had an update (and you started that thread). What more do you want?
Online jonas_sthlm
#49 Posted : 29 October 2025 22:29:57(UTC)
jonas_sthlm
It was missing updates to the user environment, particularly in terms of support for decoder settings.
Someday M and ESU needs start talk each other...
#50 Posted : 29 October 2025 23:13:25(UTC)
That ain't ever going to happen after their falling out over the cs1/ms1 and first generation mfx decoders.
2 Pages12>
This page was generated in 1.291 seconds.
