Offline garben
#1 Posted : 31 January 2025 17:36:37(UTC)
garben
Hello all.
I'll be embarking on upgrading and converting some older M Locomotives to digital. While I have the train apart I figured good time to give the wheels, gears etc a good cleaning. I'm looking for a recommendation on what solvent you may use to do this?
Thanks in advance!
Norbert
thanks 1 user liked this useful post by garben
#2 Posted : 31 January 2025 17:54:07(UTC)
Just rubbing alcohol and a cotton swab.
Offline Dave Banks
#3 Posted : 01 February 2025 01:06:04(UTC)
Dave Banks
https://www.amazon.com.au/Septon...c61752c&gad_source=1
This is the product I use in Australia & is readily available at any of our automotive stores. Does not damage the armature when washed. I wash the stripped chassis with this & a soft paint brush & the rinse under hot water & dry with a hair dryer & oil axles with one drop thereafter & reassemble. Been doing it for years.
D.A.Banks
Offline ciderglider
#4 Posted : 01 February 2025 09:48:28(UTC)
ciderglider
I've used Labelle Motor Cleaning System #109 on a couple of z scale locos which had seized up. Quite expensive, but effective. It comes with some cloths and picks to help with cleaning.
thanks 1 user liked this useful post by ciderglider
Offline Paul59
#5 Posted : 01 February 2025 10:02:20(UTC)
Paul59
I just use an aerosol of car clutch and brake cleaner.
It gives a nice jet that blasts all the muck out of the nooks and crannies of the chassis and gears. It evaporates off with no residue and leaves everything clean and dry ready for oiling.
Quick, easy and effective. I've been using it for ages.
Best to do it outside though as the muck coming out of the chassis is a bit messy.
Offline bph
#6 Posted : 01 February 2025 12:12:52(UTC)
The Märklin cleaning product is 02423, (aslo work as smoke fluid)
Two cleaning videos from Märklin (the product used in these videos is basically the same stuff as Marklin uses in their product)
and a word of caution, using a strong aerosol cleaner might damage paint, rubber and plastic parts etc. If you want to use an aerosol cleaner, look for products that are plastic, rubber and paint safe, eg some gentle electronic cleaner (non QD type) or similar that leaves no residues.
Online RudiC
#7 Posted : 01 February 2025 12:38:18(UTC)
RudiC
Yes, I use this "Reinigungsdestillat" by modellbahnprofi.com, and it is very convincing. They guarantee it doesn't harm paint nor printings nor decals nor armature / coils.
Rüdiger (Rudi)
thanks 1 user liked this useful post by RudiC
Offline analogmike
#8 Posted : 01 February 2025 15:17:12(UTC)
analogmike
Ronson Lighter Fluid. I've been using it for years. I have never had a problem with paint. Good track cleaner too.
Mikey
Offline garben
#9 Posted : 02 February 2025 18:46:43(UTC)
garben
Thank you everyone for the input. Plenty of options to try. I’m sure I’ll have the cleanest locs in town. LOL. THANKS AGAIN!
thanks 2 users liked this useful post by garben
Offline garben
#10 Posted : 03 February 2025 22:54:19(UTC)
garben
Great videos, thanks. I’m amazed that in the second video even the circuit board/decoder gets a bath? I would have assumed getting the board wet wasn’t a good thing but learn something new new. Thanks again.
Offline garben
#11 Posted : 03 February 2025 22:59:44(UTC)
garben
Correction, I just noticed that the decoder was removed before the bath, so just the interface board was soaked. Still amazed though.
Offline garben
#12 Posted : 12 February 2025 22:35:11(UTC)
garben
Hi Rudi,
Have you used the Reinigungdestillat on any of the plastic parts of a locomotive? Is it safe for plastic?
Thank you.
Online RudiC
#13 Posted : 13 February 2025 09:38:33(UTC)
RudiC
Well, "plastic" doesn't equal "plastic". I tested that stuff on PE, PP, PS, Macrolon (CD material), and on two of my Märklin locos' housings. I did not find any harm to the surface, to my satisfaction. Though I did not expose the surfaces for longer periods, just minutes.
On top I contacted the producer novadur.de who told me they had it certified by experts ("gutachterlich" in German) for cleaning delicate parts, but only the "Reinigungsdestillat", not the "Dampfdestillat" (steam fluid), and they discouraged using the latter for cleaning, even though same formulation plus some perfume, but not certified.
Of course, I cannot tell which material is used for housings between MRR manufacturers, or even between a manufacturer's product lines. I'd advise to test a droplet on interior surfaces to see if e.g. some matting occurs.
What I usually do is take off the housing so I can see the cog wheels and moving mechanics, immerse the loco into the Destillat, and run it for a few minutes, forward and reverse. As shown in the original Märklin video (and others). So I can be sure all dirt and gunk are rinsed out.
Rüdiger (Rudi)
thanks 2 users liked this useful post by RudiC
#14 Posted : 13 February 2025 13:20:58(UTC)
Maybe test the oil and grease you have on the old brittle C track made with BASF plastic and see if it melts it.
This page was generated in 0.403 seconds.
