Offline iamdutch
#1 Posted : 29 January 2025 15:56:51(UTC)
iamdutch
My analog loco (br216) is pretty much stuttering when under "100"(idk how you can call it)
It stops on some places on the rail, I need to push it. any suggestions?
thanks 1 user liked this useful post by iamdutch
#2 Posted : 29 January 2025 15:58:47(UTC)
Either it needs cleaning and orlubrication, or is just cold.
Offline Martti Mäntylä
#3 Posted : 29 January 2025 17:11:19(UTC)
Martti Mäntylä
As marklinist5999 said, plus that the brushes may need replacement.
- Martti M.
Offline iamdutch
#4 Posted : 29 January 2025 17:15:22(UTC)
iamdutch
I cleaned it already whit everything I have, but maybe the contactor is dirty or something, I should look
#5 Posted : 29 January 2025 18:42:16(UTC)
If the brushes are in good shape clean the armature commutator with a cotton swab until the carbon is gone and you see clean copper.
Offline iamdutch
#6 Posted : 29 January 2025 19:32:21(UTC)
iamdutch
thanks for the advice, but I am newbie so what and where is the brush? however I know how it looks.
#7 Posted : 29 January 2025 21:39:12(UTC)
Martti Mäntylä
Look at the explosion diagrams at 3074 and 3075. Brushes are the parts number 12 (3074) and 18 (3075). Your locomotive should match one or the other.
- Martti M.
Offline mvd71
#8 Posted : 29 January 2025 22:28:48(UTC)
Try Märklin of Sweden for learning how
Offline RudiC
#9 Posted : 29 January 2025 23:30:53(UTC)
RudiC
Originally Posted by: iamdutch Go to Quoted Post
. . . It stops on some places on the rail, I need to push it . . .
Are you sure it's not the tracks? Are the "some places" always the "same places"?
Rüdiger (Rudi)
Offline Paul59
#10 Posted : 30 January 2025 10:00:23(UTC)
Paul59
Also check the slider...
Make sure that it is clean and also straight and in line with the bogie not offset to one side or twisted.
Put a straight edge along the slider and make sure it is dead flat.
With the loco on it's back make sure the slider is about 2mm or a bit more above the wheel treads and that it is not higher at one end. If it needs adjustment tweak the spring strips that support it with a pair of fine nose pliers (carefully).
It could just be that the loco needs a good service. This is an easy one to work on so it's a good opportunity to learn about all the parts. It will stand you in good stead for the future.
Good luck, you'll get there.
Offline BenP
#11 Posted : 30 January 2025 13:04:09(UTC)
BenP
Start with cleaning rail pukos with alcohol or gently brush very fine sandpaper over them ( don't push hard). M track?
Ben
This page was generated in 0.384 seconds.
