Offline Trevor G
#1 Posted : 27 January 2025 04:48:18(UTC)
Trevor G
I have Marklin K Track and have soe issues with the points and in particular the opperation of them.
I have a lot of points and some work very well. Some, however only work in one direction.
When I fire the point motor it works as it should. However, the actual point refuses to work in one direction.
The most common senario is that it will work to use the turnout but will not fire the other way so a train can go straight though.
Is this repairable? Can the back be taken off to repair it or is there any other way.
Or is it, as I suspect a case of throwing the point out?
I also have some trouble with some points only in that the shoe will loose contact causing the loco to stall. The same loco will go over a number of points with no issue and then suddenly it stops in one.
Often the loco will go through the point in the opposite direction with no issues.
Can anyone help please?
Trevor
Offline Ross
#2 Posted : 27 January 2025 05:44:44(UTC)
Ross
Hi Trevor,
Visit my web pages below in signature and select the tips section
Ctrl-F and search for 7459
You should get some ideas to solve your point problem.
Trevor
Ross
Offline Trevor G
#3 Posted : 27 January 2025 07:24:19(UTC)
Trevor G
Hi Trevor,
Trevor
Thanks Ross,
I have read through the information and as I am not electrical I am finding it hard to understand.
Will need some time to decipher.
However, I am not having any trouble in firing the solenoids. They work every time. It is the tongue going into the pionts and making the connection inside the points that appears to be the main issue.
I have looked to see if they can be opened to check the workings but that does not seem like an easy opperation.
I have noticed that the motor needs to be in an exact position so I am currently working aruond them to see if that is an issue.
Any other ideas are very welcome and I will certainly be looking into your findings.
I did forget to say I am using m83's off the track. The controler is a CS3 Command Station.
Trevor
ps. I notice a lot of other tips on your site so will be looking there as well.
Thanks for all your work.
thanks 1 user liked this useful post by Trevor G
Offline Copenhagen
#4 Posted : 27 January 2025 12:10:11(UTC)
Copenhagen
I have no experience with K tracks. When I built my C track layout I noticed some of the turnouts didn't shift as fast, well or smooth as desired so I used some teflon spray (or lubricating spray with teflon, also called ptfe spray) on various moving parts and it did help. Be sure to let it dry down and wipe off any excess. Don't know if it will work on K turnouts.
Offline PMPeter
#5 Posted : 27 January 2025 16:20:23(UTC)
PMPeter
Are you referring to the old style K track switches with the built in solenoids or the newer style with the detachable solenoids?
Offline Trevor G
#6 Posted : 27 January 2025 18:42:50(UTC)
Trevor G
Thanks. Have tried similar with silicon. Will see what else is on the market here.
Offline Trevor G
#7 Posted : 27 January 2025 18:53:30(UTC)
Trevor G
Never come across different types.
IMG20250128062914.jpg shows what I have
IMG20250128062926.jpg Solinoids are working. The Tongue arrowed moves in and out as they are meant to.
IMG20250128063107.jpg The levers arrowed will work in one direction but not always back again.
This leads me to believe there is a faulty lever inside. May have come off its mounting or the movong part of the point is sticking somewhere.
Are the points themselves serviceable?
Can you get in the back of them & if so how?
As I said it is not the point motor that is the issue. It is the mechanisum inside the point.
Trevor
Offline Ross
#8 Posted : 27 January 2025 21:59:56(UTC)
Ross
Hi Trevor,
It looks like you are using a standard curve point 2262 2263.
The points are not serviceable.
The point motor must be flat with the track bed not raised or lowered.
Have you tried a different point motor?
The size of the point motor tongue can vary, if you have several motors measure them until you find a different size then try that.
Make sure ther are no flash marks on the tongue as these can catch and stop the point working.
If you have a manual hand lever remove the tongue from the mounting and use it to test the point movement. Your fingers will feel if there is any catching or stiffness.
If the point blades catch and the movement in the point mechanism switches then the surfaces around and under the point blades need to be cleaned.
If the point mechanism catches ensure there isn't any rust on the metal surfaces.
As a last resort use a dry lubricant such as teflon powder don't use wet lubricants!
Hope the above suggestions help track the problem down.
Trevor
Ross
Offline FastEddie
#9 Posted : 27 January 2025 22:18:40(UTC)
FastEddie
You have the newer, less reliable K track switches. The new ones look far more prototype and less massive but are far less reliable. Several sthoughts for you:
1. The solenoids have a little plastic tab that sticks up and moves fully right or left when the solenoid works correctly. If one side of the solenoid is not getting enough power, you will find the little tab is not all the way over and the points are not all the way opened or closed. This is the typical problem with K track switches.
2. If you do not have the points right when you slide the plastic tongue from the solenoid motor into the switch it wont seat right and your switch will not work properly. The plastic tongue has to be fully extended and the switch points have to be either fully opened or closed (I can't remember which) to seat the tongue properly in the switch.
3. If you pull a failing solenoid motor from its track position and test it by directly connecting it to the auxiliary ports on your transformer it will usually work fine, but when reinstalled on your actual layout it will not get the same voltage and will fail to close completely in one direction (at least that is true on analog set ups).
thanks 1 user liked this useful post by FastEddie
Offline Trevor G
#10 Posted : 28 January 2025 01:05:05(UTC)
Trevor G
Hi Trevor,
Trevor
Thanks Ross. Some good points. I have tried to get them flat but perhaps more attention to that will help.
You have been very helpful.
Trevor
Offline Trevor G
#11 Posted : 28 January 2025 01:06:45(UTC)
Trevor G
Thanks FastEddie,
Some good points to check out.
Trevor
Offline Kiko
#12 Posted : 28 January 2025 06:15:12(UTC)
Kiko
Hello Trevor,
For far too many years I was struggling with my K-track layout turnouts (and I have a lot of them). They would work for a while but then become unreliable once again. I was at my wits ends because unreliable operations makes you stay away from running trains. I took out all these switches and replaced them all with Tortoises. The best investment I ever made. Now, I never have to worry about a turnout not switching when it's told to switch.
Just a side comment, but spoken from personal experience.
Andry
Andry
Offline Trevor G
#13 Posted : 28 January 2025 07:08:10(UTC)
Trevor G
Hello Trevor,
Andry
Thanks Angy, I tried that with DCC Concepts motors that are similar.
The biggest issue I had with them was connecting to the points.
Can you please take a photo and post it along with a description on how you did it please?
I also have double slips. Does it work on those?
Offline Kiko
#14 Posted : 28 January 2025 16:34:55(UTC)
Kiko
Hello Trevor,
I've attached a few pictures of how I mounted the Tortoise switch machines. The pictures are from the unfinished part of my layout so that you can see how the points are connected. There's also a picture of a crossover switch.
As you can see, some Tortoises are mounted on top of the layout (hidden part), and on the visible part of the layout they are mounted underneath. How you mount them is really your decision. There are multiple examples on the web. Also, the electrical connections are quite simple -- many diagrams on the web as well. Each Tortoise has a stall motor (i.e., it always draws a tiny amount of current) to keep the points firmly closed. Tortoise motors can be driven with any DC source (8-24 volts). The lower the voltage, the slower they move (nice and prototypical). To move the points (straight or curve), the polarity of the Tortoise is reversed. This can be achieved in a variety of ways -- a toggle switch being the simplest way. I use relays (you can see them mounted on the Tortoises), because my layout is automated and controlled digitally (DCC) by software.
I hope this helps. Let me know if anything is still unclear.
Andry
thanks 1 user liked this useful post by Kiko
#15 Posted : 28 January 2025 19:04:27(UTC)
Biggest problem I have with tortoise motors is the cost, and also their physical size.
I would suggest looking at using R/C servos, there are decoders around that will drive them. Fitting them to points is similar to how you would use a tortoise.
Offline Kiko
#16 Posted : 28 January 2025 19:16:14(UTC)
Kiko
Hello Alan,
When I grew tired of the problems with Marklin solenoids, I experimented with both servos and Tortoises. Servos are fairly inexpensive, but "you get what you pay for". The cheaper ones do have a problem with RF interference. I tried ferroid coils and other tricks, but they were not 100% reliable. You had to make sure that the travel was right because if not, they tend to burn out. Also, they are not "stall motors", hence the possiblity of points not fully closed when the servo stops moving and "relaxes". You are correct -- the Tortoises are more expensive (about the same price as the Marklin solenoids) and are quite bigger in size. However, on my layout, there's plenty of room underneath or on top (see previous pictures).
I guess what I'm saying is that it's "to each his own". Whatever works for your layout and whatever you're happy with. We all have to make compromises in building out railroad empire! BigGrin
Andry
Offline Ross
#17 Posted : 28 January 2025 20:04:23(UTC)
Ross
Hi Andry/All,
?si=14N54XxhPIPMpwDG
You may change your mind when you see the above.
Ross
thanks 3 users liked this useful post by Ross
Offline Kiko
#18 Posted : 29 January 2025 00:13:09(UTC)
Kiko
Hello Ross,
Good info. However, as the speaker mentions, they never had a Tortoise motor fail. Tortoise motors is all I use -- I don't use the other options of the Tortoise, i.e., "point feedback" nor "frog power" (no need with Marklin 3-rail).
So I think I'm safe! BigGrin
Andry
Offline Ross
#19 Posted : 29 January 2025 03:26:42(UTC)
Ross
Hi Andry,
Just because you aren't using the contacts doesn't mean the contacts won't become loose and do internal damage Blushing
Have you checked the contacts?
Hello Ross,
Ross
Offline Kiko
#20 Posted : 29 January 2025 05:43:48(UTC)
Kiko
No, I have not checked. It would not be an easy task to check the contacts since I'd have to remove the Tortoise from its mounting position. Because this is only a hobby, I prescribe to the motto "if it ain't broke, don't fix it". They've been going strong for 10 years (or so) -- probably will outlive me -- and I've yet to have one fail or misalign a turnout.
In any case, it's always good to know what can go wrong in case one needs to fix something.
Thanks.
Andry
Offline applor
#21 Posted : 31 January 2025 00:00:10(UTC)
applor
*removed*
Edited by user 01 February 2025 15:54:14(UTC)  | Reason: Not specified
This page was generated in 0.579 seconds.
